查看: 5288|回复: 2
[求助] VIVADO 约束一个差分输出,要求是1.8V
发表于 2019-7-3 16:28:29 | 显示全部楼层 |阅读模式
OBUFDS #(
    .IOSTANDARD("DEFAULT"), // Specify the output I/O standard
    .SLEW("SLOW") // Specify the output slew rate
    ) OBUFDS_inst (
    .O(CLK4_P), // Diff_p output (connect directly to top-level port)
    .OB(CLK4_N), // Diff_n output (connect directly to top-level port)
    .I(clk40M) // Buffer input
要求是输出一个40M差分输出,但是在约束的时候,出现了问题
[DRC 23-20] Rule violation (BIVC-1) Bank IO standard Vcc - Conflicting Vcc voltages in bank 13. For example, the following two ports in this bank have conflicting VCCOs:  CLK4_P (DIFF_SSTL18_I, requiring VCCO=1.800) and SDIO (LVCMOS33, requiring VCCO=3.300)
请问这种电压标准怎么修改
 楼主| 发表于 2019-7-3 18:51:23 | 显示全部楼层
有没有大佬带带我啊,自己顶一下!!~!!!
 楼主| 发表于 2019-7-3 22:25:00 | 显示全部楼层
已经解决,使用ODDR
GMT+8, 2025-10-8 20:07 , Processed in 0.012056 second(s), 3 queries , Gzip On, Redis On.
