查看: 15810|回复: 25
用scl_keygen生成的license,用sssverify检查时Failed
发表于 2019-6-21 14:39:02 | 显示全部楼层 |阅读模式
悬赏1000资产已解决
安装了vcs_vM-2017.03-SP2,SCL用的是scl_v11.11,OS是CentOS6.10。
按照网上的信息,scl_keygen生成的license。使用vcs时,编译可以通过,但运行./simv时报错误:
Dumping VCS Annotated Stack:
#0  0x0000003085eac8dd in waitpid () from /lib64/libc.so.6
#1  0x0000003085e3e4e9 in do_system () from /lib64/libc.so.6
#2  0x0000003085e3e820 in system () from /lib64/libc.so.6
#3  0x00002aaaab4cb70b in SNPSle_10ee25eff68cd8461c9146fa1d0b35e87067f3c8015b313e639d2928478c79b3f673f99203bcf8be64600612100082236bffb2007f1e0ef9 () from /home/mp/eda/synopsys/vcs_vM-2017.03-SP2/linux64/lib/liberrorinf.so
#4  0x00002aaaab4ccda6 in SNPSle_10ee25eff68cd8461c9146fa1d0b35e87067f3c8015b313efba706aab251478fa49e66610e453774633a6c152e7ef778f2202cda681f3d4e () from /home/mp/eda/synopsys/vcs_vM-2017.03-SP2/linux64/lib/liberrorinf.so
#5  0x00002aaaab4c61e5 in SNPSle_d35ca1ff70d465c2b9b1a72eee90a506fdd009d3de3db1de () from /home/mp/eda/synopsys/vcs_vM-2017.03-SP2/linux64/lib/liberrorinf.so
#6  0x00002aaaad78d768 in SNPSle_64133461705005bb725549e2e6fa1b3f () from /home/mp/eda/synopsys/vcs_vM-2017.03-SP2/linux64/lib/libvcsnew.so
我用sssverify验证license文件时,也是Failed:
Licensed to student@eetop
Siteid: 26356, Server Hostid: 206a8a5b5a38, Issued on: 1/8/2014
License file integrity check FAILED!
This is an INVALID license file. You SHOULD NOT use this license file.
Please use the license file as received from Synopsys, Inc.
请大侠提供解决方法,可以提供报酬。联系邮箱:ma8301@163.com
最佳答案
查看完整内容
https://pan.baidu.com/s/1b6uDWE#list/path=%2F Download those files. Then extract the rar files to a folder. Open the vmx in vmware workstation pro 15. power on the virtual machine. *** and then click I moved it,, not I copied it.** then login with password: 123456 if not work shutdown the guest os and then shut down the host os too. then power on and try again. And it will work...
发表于 2019-6-21 14:39:03 | 显示全部楼层
And it will work...
发表于 2019-6-21 23:06:59 | 显示全部楼层
try this...
at first power on time ***click I moved it***
发表于 2019-6-22 02:33:17 | 显示全部楼层
vcs2017 also working..
I am using it..
发表于 2019-6-22 13:24:18 | 显示全部楼层
license使用 sssvrifycheck不通过, VCS 肯定不能用的。反过来就是check通过了,你这个VCS也有可能不被license支持。
发表于 2019-6-22 13:49:37 | 显示全部楼层
I am using it..
能否分享一下方法?
发表于 2019-6-22 17:35:44 | 显示全部楼层
86497689 发表于 2019-6-22 13:49
能否分享一下方法?
Delete the pre installed vcs.
Install vcs2017.
sutdown guest and host os too..
Then power on again..
Simple...
发表于 2019-6-22 23:18:11 来自手机 | 显示全部楼层
查一下是不是有重复的feature
发表于 2019-6-23 00:48:07 来自手机 | 显示全部楼层
我也说一句
发表于 2019-6-23 18:29:22 | 显示全部楼层
111
GMT+8, 2025-10-3 15:56 , Processed in 1.335265 second(s), 4 queries , Gzip On, Redis On.
