查看: 7082|回复: 15
xcelium 安装出错
发表于 2019-5-3 12:14:35 | 显示全部楼层 |阅读模式
一点start 安装就发现弹出java的异常了 无法继续下去,是不是安装包有问题啊?
Initializing InstallScape using JVM at /home/soft/IScape/IScape04.23-s012/iscape.04.23-s012/runtime/LNX86/bin/java. This might take some time...
Use -help option for details on usage....
java.lang.reflect.InvocationTargetException
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
        at java.lang.reflect.Method.invoke(Unknown Source)
        at com.khanpur.installer.gui.nginterface.ISCVBottomButtonBar.callMethod(ISCVBottomButtonBar.java:105)
        at com.khanpur.installer.gui.nginterface.ISCVBottomButtonBarButton.actionPerformed(ISCVBottomButtonBarButton.java:32)
        at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
        at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
        at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
        at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
        at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
        at java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
        at java.awt.Component.processMouseEvent(Unknown Source)
        at javax.swing.JComponent.processMouseEvent(Unknown Source)
        at java.awt.Component.processEvent(Unknown Source)
        at java.awt.Container.processEvent(Unknown Source)
        at java.awt.Component.dispatchEventImpl(Unknown Source)
        at java.awt.Container.dispatchEventImpl(Unknown Source)
        at java.awt.Component.dispatchEvent(Unknown Source)
        at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
        at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
        at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
        at java.awt.Window.dispatchEventImpl(Unknown Source)
        at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
        at java.awt.EventQueue.access$000(Unknown Source)
        at java.awt.EventQueue$1.run(Unknown Source)
        at java.security.AccessController.doPrivileged(Native Method)
        at java.security.AccessControlContext$1.doIntersectionPrivilege(Unknown Source)
        at java.awt.EventQueue$2.run(Unknown Source)
        at java.awt.EventQueue.dispatchEvent(Unknown Source)
        at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
        at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
        at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
        at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
        at java.awt.EventDispatchThread.run(Unknown Source)
Caused by: java.lang.NullPointerException
        at com.khanpur.installer.gui.nginterface.SLAExceptionClassicView.<init>(SLAExceptionClassicView.java:53)
        at com.khanpur.installer.gui.nginterface.ISClassicView.installReleases(ISClassicView.java:1354)
        at com.khanpur.installer.gui.nginterface.ISClassicView.right_media_status(ISClassicView.java:1056)
        ... 43 more
Exception occured: setAttr ite
发表于 2019-5-3 17:26:59 | 显示全部楼层
我能确定安装包应该没有问题
发表于 2019-5-3 20:11:43 | 显示全部楼层
32bit java
 楼主| 发表于 2019-5-4 18:37:13 | 显示全部楼层
hspice 发表于 2019-5-3 17:26
我能确定安装包应该没有问题
是百度云下载的有问题,文件不完整
发表于 2020-5-21 02:39:21 | 显示全部楼层
楼主,这个是如何安装的呢,不会用Install scape
发表于 2020-9-13 15:07:49 | 显示全部楼层
roc2007 发表于 2019-5-4 18:37
是百度云下载的有问题,文件不完整
.cshrc怎么配置
 楼主| 发表于 2020-9-13 18:04:16 | 显示全部楼层
lv6336 发表于 2020-9-13 15:07
.cshrc怎么配置
和ies 15.2 一样啊,指过去就好了
发表于 2020-9-15 23:25:45 | 显示全部楼层
能把你的配置给我发一下吗   我看了好像二个还不太一样
 楼主| 发表于 2020-9-16 01:24:51 | 显示全部楼层
export CDS_AUTO_64BIT=ALL
#export CDS_LIC_FILE=28000@roc.nb.centos:/home/roc/soft/license/cadence152.dat
#export CDS_INST_DIR="/home/roc/soft/IES/INCISIVE151"
## ies152
#export CADENCE=/home/roc/soft/cadence/INCISIVE152
#export CDS_INST_DIR="/home/roc/soft/cadence/INCISIVE152"
#export PATH=$PATH:/home/roc/soft/cadence/INCISIVE152/tools/bin/64bit
#xcelium
export XCELIUM=/home/roc/soft/cadence/XCELIUM1909/tools/bin/64bit
export CDS_INST_DIR="/home/roc/soft/cadence/XCELIUM1909"
export PATH=$PATH:/home/roc/soft/cadence/XCELIUM1909/tools/bin/64bit
发表于 2020-9-17 15:12:13 | 显示全部楼层
#export CDS_LIC_FILE=28000@roc.nb.centos:/home/roc/soft/license/cadence ...
这个license必须要单独?不能跟cadence共用一个吗?
GMT+8, 2025-12-26 05:30 , Processed in 0.021582 second(s), 6 queries , Gzip On, Redis On.
