查看: 1200|回复: 1
[招聘] 终端后台测试
发表于 2019-3-26 09:34:57 | 显示全部楼层 |阅读模式
Back Office for Stability Test
Responsibilities / Tasks:
With good knowledge on TD-LTE/ TD-SCDMA testing and debugging. Taking action and following up on failures:
·         Analyze the trace for the defect found in stability testing and locate the subcomponent with the problem. Responsible for debug and follow-up including support to development for resolving issues.
·         Identify and categorize CR for the issue and submit ticket in UTP.
·         Make sure the CR with precise subcomponent, sufficient information, correct description and correct duplicated & rejected keywords.
Qualifications:
·         Bachelor / Master in telecommunication engineering or information technology required.
·         Work experience at least 2 years with relevant area.
·         Experiences in test and verification of telecommunications equipment, good knowledge on TD-LTE/TD-SCDMA FW and PS development.
·         Experience with good understanding of TD-LTE, TD-SCDMA and 2/3G standards.
·         Experience in trace analysis on UE and NW side.
·         Programming skills: experience with Python, Perl, Java scripting languages preferred.
·         Test design, authoring, manual and automated test execution and follow-up.
·         Assist in debugging and handling of defect reports.
·         Good teamwork and communication skills.
·         Ready to integrate into international team.
·         Independent way of working, proactively tackling issues.
·         Some travelling will be required.
·         English  required.
 楼主| 发表于 2019-3-26 12:50:19 | 显示全部楼层
GMT+8, 2025-12-18 06:08 , Processed in 0.013718 second(s), 4 queries , Gzip On, Redis On.
