查看: 2350|回复: 1
[求助] uvm_reg_field构造问题
发表于 2019-3-13 10:56:15 | 显示全部楼层 |阅读模式
在寄存器模型构造中
virtual function void build();       UsePageSelect = uvm_reg_field::type_id::create("UsePageSelect",,get_full_name());
和  UsePageSelect = uvm_reg_field::type_id::create("UsePageSelect");有什么区别吗
 楼主| 发表于 2019-3-13 13:59:34 | 显示全部楼层
回复 1# 851018986@qq.co
type_name::type_id::create(string name, uvm_component parent)
Since the create() method is automatically type-specific, it may be used to create components or objects.
When creating objects, the second argument, parent, is optional.
GMT+8, 2025-12-17 08:06 , Processed in 0.014834 second(s), 4 queries , Gzip On, Redis On.
