查看: 6829|回复: 16
[资料] 利用CDS消除offset
发表于 2019-3-8 09:40:17 | 显示全部楼层 |阅读模式
1.有点像把噪声当失调处理了
2.可能对于随机失调有一定的消除作用
2篇文章,需要的看看
cds-offset1.pdf (793.77 KB , 下载次数: 189 )
cds-offset2.pdf (826.86 KB , 下载次数: 172 )
发表于 2019-3-8 21:00:52 | 显示全部楼层
thanks
发表于 2019-3-9 07:43:24 | 显示全部楼层
非常感謝~~~~
发表于 2019-3-10 17:31:18 | 显示全部楼层
谢谢分享
发表于 2019-3-26 12:29:40 | 显示全部楼层
下载看看
发表于 2019-3-26 13:24:18 | 显示全部楼层
Correlated double sampling (CDS) is a method to measure electrical values such as voltages or currents that allows removing an undesired offset.
It is used often when measuring sensor outputs.
The output of the sensor is measured twice: once in a known condition and once in an unknown condition. The value measured from the known condition is then subtracted from the unknown condition to generate a value with a known relation to the physical quantity being measured.
发表于 2019-5-17 11:06:41 | 显示全部楼层
have a look
发表于 2019-5-17 18:00:28 | 显示全部楼层
謝謝分享
发表于 2019-5-17 21:11:16 | 显示全部楼层
2.Noise Analysis of a CDS Circuit with Offset
Canceling
1.Optimization Design for a CDS Circuit with Offset
Canceling
两篇文章的名称
发表于 2019-5-18 14:03:06 | 显示全部楼层
非常感謝!!!!!
GMT+8, 2025-12-29 00:34 , Processed in 0.019764 second(s), 6 queries , Gzip On, Redis On.
