查看: 7570|回复: 9
[求助] ADE spectre 仿真求助
发表于 2019-1-25 00:42:56 | 显示全部楼层 |阅读模式
工艺库之前用AMS仿真一切正常,后来改用spectre仿真,发现电容不能使用,会出现如下错误,请各位大神支招小弟,不胜感谢!
Internal error found in spectre during AHDL read-in, in `crtmom':`C0', during hierarchy flattening, during circuit read-in.
Encountered a critical error during simulation. Submit a Service Request via Cadence Online Support, including the netlist, the Spectre log file, the behavioral model files, and any other information that can help identify the problem.
    FATAL (SPECTRE-18): Segmentation fault.
发表于 2019-11-13 11:03:23 | 显示全部楼层
Internal error found in spectre at time = 5.30645 us during transient analysis `tran'.
How to solve this problem  thanks !
发表于 2019-12-14 20:55:15 | 显示全部楼层
Internal error found in spectre during initial setup.
Any body encounter??Thanks!
发表于 2019-12-14 20:56:07 | 显示全部楼层
Any body encounter?? Thanks!!
发表于 2021-8-10 20:33:09 | 显示全部楼层
你这个问题解决了吗?怎么处理的?
发表于 2022-5-16 12:31:40 | 显示全部楼层
顶顶顶顶顶。
发表于 2024-8-11 21:58:11 | 显示全部楼层
请问该如何解决
发表于 2024-8-11 23:27:42 | 显示全部楼层
在spectre的setup-Environment中勾选run with 64-bit binary,并且在user command-line options中输入-64
可以解决
发表于 2025-3-5 09:58:59 | 显示全部楼层
不大行啊…还是挂
发表于 2025-5-16 15:21:12 | 显示全部楼层
qibaojin 发表于 2025-3-5 09:58
不大行啊…还是挂
我现在也这样,用了上面的方法也没有效果,楼主解决了没呀?
GMT+8, 2025-12-26 07:45 , Processed in 0.026910 second(s), 4 queries , Gzip On, Redis On.
