查看: 4052|回复: 3
centOS7 安装vcs2014 的问题
发表于 2019-1-9 22:35:15 | 显示全部楼层 |阅读模式
usr/synopsys/license/synopsys.dat:行1257: FEATURE: 未找到命令
/usr/synopsys/license/synopsys.dat:行1258: SUPERSEDE: 未找到命令
/usr/synopsys/license/synopsys.dat:行1260: FEATURE: 未找到命令
/usr/synopsys/license/synopsys.dat:行1261: SUPERSEDE: 未找到命令
/usr/synopsys/license/synopsys.dat:行1263: FEATURE: 未找到命令
/usr/synopsys/license/synopsys.dat:行1264: SUPERSEDE: 未找到命令
/usr/synopsys/license/synopsys.dat:行1266: FEATURE: 未找到命令
/usr/synopsys/license/synopsys.dat:行1267: SUPERSEDE: 未找到命令
[root@localhost bin]# 22:33:42 (snpslmd) lmgrd version 11.10, snpslmd version 11.9
01/09/2019 22:33:42 (snpslmd) Synopsys Corporate Licensing (SCL) Release: version SCL_11.7
22:33:43 (snpslmd) Server started on localhost.localdomain for:    SSS
22:33:43 (snpslmd) nanochar    hspice_pack    cosmos_other
22:33:43 (snpslmd) cxp        Synopsys_VCS_cmv Design-Expert
22:33:43 (snpslmd) him_mm_pi    CXp_GUI        CXp_Analysis
22:33:43 (snpslmd) CXp_CircuitEnvironment COSMOS_SCOPE    COSMOS_SCOPE
22:33:43 (snpslmd) CmMonitor    VCSiRuntimeLimited_Node VCSiRuntimeLimited_Net
22:33:43 (snpslmd) VMCCompiler_Node VMCRuntime_Node VMCEvaluation_Node
22:34:00 (snpslmd) Licenses are case sensitive for TE_CATS
22:34:00 (snpslmd)
22:34:00 (snpslmd) EXTERNAL FILTERS are OFF
22:34:00 (lmgrd) snpslmd using TCP-port 51219
22:34:00 (snpslmd) Serving features for the following vendor names:
snpslmd  ACAD  adalmd  anagram  arcd  archprod  avantd  CADABRA  chrysalisd  cowared  EPIC  eved  everest  extremed  hscd  innologd  ISE-TCADd  knights  la_dmon  leda  magma  metasoftd  mwflexd  nassd  nsysnvs  numeritchd  pdld  riod  saber_dmn  sandwork  sclmgrd  sigmacd  slat  snpsOEM1  snpsOEM2  snpsOEM3  snpsOEM4  snslmgrd  ssilmd  synforad  synopsysd  synplctyd  TAVEREN  TE_CATS  tmald  vastlmd  vcsd
01/09/2019 22:34:00 (snpslmd) Error at sclLicenseFileGetServerInfo
01/09/2019 22:34:00 (snpslmd) Error opening the license file 27000@localhost.localdomain
22:34:00 (lmgrd) snpslmd exited with status 1 signal = 17
22:34:00 (lmgrd) Please correct problem and restart daemons
小弟第一次发帖哈,这几天都在破解vcs被搞得苦不堪言,是在解决不了了,请各位大神帮我解惑!谢谢啦
# .bashrc
# User specific aliases and functions
alias rm='rm -i'
alias cp='cp -i'
alias mv='mv -i'
# Source global definitions
if [ -f /etc/bashrc ]; then
    . /etc/bashrc
fi
#dve
export PATH="/usr/synopsys/vcs2014/gui/dve/amd64/bin:"$PATH
#VCS
export PATH="/usr/synopsys/vcs2014/bin:"$PATH
#lmgrd
export PATH="/usr/synopsys/scl11.7/amd64/bin:"$PATH
#start synopsys license using lmgrd
alias lmli2="/usr/synopsys/scl11.7/amd64/bin/lmgrd -c
/usr/synopsys/license/synopsys.dat -l /usr/synopsys/scl11.7/amd64/bin/lmgrd.log"
export SNPSLMD_LICENSE_FILE=27000@localhost.localdomain
export LM_LICENSE_FILE=/usr/synopsys/license/synopsys.dat
export VCS_HOME="/usr/synopsys/vcs2014"
export DVE_HOME="/usr/synopsys/vcs2014/gui/dve"
alias vcs="vcs -full64"
alias dve="dve – full64
这是.bashrc环境变量文件
#Synopsys SCL v10.9.1 License File, Generated by Team ZWT 2006.
#For EVALUATION only. If you like this software, BUY it!
SERVER localhost.localdomain 2089845224f8 27000
VENDOR snpslmd /usr/synopsys/scl11.7/amd64/bin/snpslmd
#USE_SERVER
FEATURE SSS snpslmd 1.0 31-dec-2020 uncounted 7E5EF02962D8CF7B169D \
    VENDOR_STRING="69656 d1d88 34cc3 300be 15c01 bf5f8 dcf43 8258f \
    ecc22 fcf" NOTICE="Licensed to mammoth//ZWT 2006 [PLEASE DO NOT \
licese文件头
有情各位大佬帮忙阿!!
 楼主| 发表于 2019-1-10 09:28:07 | 显示全部楼层
自己先顶一下
 楼主| 发表于 2019-1-11 15:33:10 | 显示全部楼层
发表于 2020-4-27 19:29:35 | 显示全部楼层
解决了吗,我也遇到了
GMT+8, 2025-12-13 17:27 , Processed in 0.027673 second(s), 3 queries , Gzip On, Redis On.
