查看: 5984|回复: 15
Spark Current in Charge Pump of Phase Lock Loop
发表于 2007-11-15 12:30:53 | 显示全部楼层 |阅读模式
Charge pump is one of the key units in a Phase Lock Loop (PLL) [1].  The operation principle of a charge pump is the current charges to and discharges from a capacitor.  Therefore, it is a current sensitive circuit.  Spark current is the current that flows directly through the gate and the drain of a MOSFET during a transition of gate voltage.  Since it depends on the gate voltage change ratio, dV/dt, not controlled by the gate voltage, the spark current would degrade the performance of circuits such as the charge pump of a phase lock loop when MOSFETs are used as the current control devices in the charge pump.  The paper studies the spark current generation mechanism, the asymmetry of the rising edge and the falling edge and the deduction methods.
[ 本帖最后由 ohyoung 于 2007-11-15 12:32 编辑 ]
Spark Current in Charge Pump of Phase Lock Loop.pdf
149.87 KB, 下载次数: 67 , 下载积分: 资产 -2 信元, 下载支出 2 信元
电荷泵电流毛刺
发表于 2007-12-5 22:58:58 | 显示全部楼层
dingdingdingdingding
发表于 2009-1-21 18:56:40 | 显示全部楼层
Do you have charge pump circuit design?
发表于 2009-3-1 15:11:13 | 显示全部楼层
Thanks for sharing!!!
发表于 2009-4-6 16:12:39 | 显示全部楼层
貌似有点概念性东西的说
发表于 2009-4-23 14:40:35 | 显示全部楼层
thank you
发表于 2009-5-22 15:43:56 | 显示全部楼层
thanks..Great Post!
发表于 2009-6-25 10:53:43 | 显示全部楼层
谢谢
谢谢谢谢谢谢谢谢谢谢谢谢谢谢谢谢谢谢谢谢谢谢
发表于 2009-6-27 20:10:45 | 显示全部楼层
thanks
发表于 2011-4-1 05:09:43 | 显示全部楼层
very useful
GMT+8, 2025-12-7 06:09 , Processed in 0.026427 second(s), 6 queries , Gzip On, Redis On.
