查看: 1668|回复: 3
[求助] Help! Upload "A 130 MHz 8-Bit CMOS Video DAC for HDTV Applications"
发表于 2018-12-10 09:41:49 | 显示全部楼层 |阅读模式
Please upload the following paper for me. Thank you very much.
https://www.semanticscholar.org/paper/A-130-MHz-8-Bit-CMOS-Video-DAC-for-HDTV-Fournier-Senn/0a58bf0f1400e7ec984e6cf350ac70178e968612
J.M. Fournier, Patrice SennPublished 1990 in ESSCIRC '90: Sixteenth European Solid-State…
A 130 MHz CMOS video DAC with a current output for HDTV applications will be described. In order to achieve monotonicity and a high speed performance,a current cell matrix configuration and a parallel decoding circuit with one stage latches have been used. P channel devices used as current sources insure a low noise level and a ground referenced voltage output in double adaptation load (38 ohms / 20 pF). The experimental results have shown that the maximum conversion rate is 130 MHz and the integral and differential linearity errors are less than 0.5 LSB. The maximum glitch energy is 50 pS.V. The DAC has been developed in a 1 ¿m digital/analog CMOS technology. It dissipates 150 mW at a 130 MHz conversion rate. LESS
发表于 2018-12-10 10:30:53 | 显示全部楼层
fournier1991.pdf (454.28 KB , 下载次数: 35 )
enjoy~
 楼主| 发表于 2018-12-10 12:07:55 | 显示全部楼层
回复 2# univerw
Thank you so much.
发表于 2019-3-12 14:33:14 | 显示全部楼层
thanks
GMT+8, 2025-12-29 20:45 , Processed in 0.018658 second(s), 4 queries , Gzip On, Redis On.
