查看: 7582|回复: 25
[求助] 找书Time to Digital Conversion: An Alternative View on Synchronization
发表于 2018-12-10 00:33:00 | 显示全部楼层 |阅读模式
哪位大神能帮忙提供一下这本书。急用!多谢多谢
Time to Digital Conversion: An Alternative View on SynchronizationLink: https://link.springer.com/chapter/10.1007/978-1-4020-8944-2_6
Author:
  • J. Daniels
  • W. Dehaene
  • M. Steyaert
Abstract:
A new scheme for a fully-digital Clock and Data Recovery (CDR) circuit is proposed which combines immediate acquisition with a continuous frequency range. It uses a Time to Digital Converter (TDC) that measures the position on the time axis of the incoming data edges. This time information is passed to a decision block which extracts the clock and data information. A waveform generator is then used to reconstruct the original data along with the synchronized clock. A survey on TDCs is given followed by a comparison of the new CDR architecture with known topologies. A design example of a prototype TDC is presented with a wide operation range and adjustable time resolution.
补充内容 (2020-9-18 01:20):
楼主已找到该书,并在23楼上传,请各位同仁笑纳
发表于 2018-12-10 09:47:19 | 显示全部楼层
发表于 2018-12-10 10:52:19 | 显示全部楼层
试了几次还是上传失败,eetop这功能不好使啊。。。
enjoy~~
发表于 2018-12-10 11:06:28 | 显示全部楼层
上面的分卷好挫啊。。。
发表于 2018-12-10 13:20:06 | 显示全部楼层
enjoy~~
发表于 2018-12-10 16:02:07 | 显示全部楼层
thank you!
发表于 2018-12-10 20:40:27 | 显示全部楼层
thank you!
发表于 2018-12-10 20:42:00 | 显示全部楼层
thnx!
发表于 2018-12-11 02:34:04 | 显示全部楼层
Thanks
发表于 2018-12-11 08:47:25 | 显示全部楼层
thank
GMT+8, 2025-9-12 03:04 , Processed in 0.017703 second(s), 3 queries , Gzip On, Redis On.
