查看: 4562|回复: 2
[求助] vhdlan 解析找不到unisim库 ?
发表于 2018-12-9 14:54:49 | 显示全部楼层 |阅读模式
使用vhdlan -full64 -f filelist_vhdl.vhdl -y /EDA/xilinx_lib/unisim -l vhdl.log对vhdl文件进行解析,是否需要加库 -y /EDA/xilinx_lib/unisim?
出现如下提示:
Parsing design file '../../../../user/HDMI_SRC/HDMI_FPGA_ML_A7_0/src/TMDSEncoder.vhd'
Parsing design file '../../../../user/HDMI_SRC/HDMI_FPGA_ML_A7_0/src/SerializerN_1.vhd'
Error-[XSYMTABNOLIBMAP] Missing library map
  Library logical name 'UNISIM' is not mapped to a host directory.
  The show_setup command shows all of the mappings for the libraries.  Please
  use this command to validate that the named library above is mapped to a
  physical directory in your synopsys_sim.setup file.
发表于 2018-12-11 10:47:18 | 显示全部楼层
要在synopsys_sim.setup里加上:
unisim: $unisim_path/64,其中$unisim_path需要具体的路径
 楼主| 发表于 2018-12-11 14:10:16 | 显示全部楼层
感谢,vcs和vivado的版本 没有匹配造成的
GMT+8, 2025-10-12 17:54 , Processed in 0.010605 second(s), 3 queries , Gzip On, Redis On.
