查看: 2659|回复: 1
[求助] 后端标准单元库-Liberate for library characterization
发表于 2018-12-8 10:09:28 | 显示全部楼层 |阅读模式
之前都是对组合逻辑单元,用liberate生成lib,虽然结果可能不是特别正确,但是报错的地方很少。但是当加入了一个时序的DFF触发器后,在生成中出现了很多错误。类似这样的:ERROR (LIB-52): The constraint search failed to find a solution within the search range for arc of cell:'DFM1RA_st', r_pin:'CK', r_pin dir:'r', pin:'D', pin dir:'r', type:'hold_rising rise_constraint', vector:'RRxx'. This cell will be marked as failed and the constraint data will be set to: 1.0 (see constraint_failed_value). To debug, review the saved simulation results for deck: hold_5. Possible causes include: 'constraint_delay_degrade' too large; 'constraint_delay_degrade_abstol' too large; 'constraint_check_final_state_threshold' too large; estimated search range too small (see constraint_search_bound). Modify the constraint parameters and rerun.
ERROR (LIB-52): The constraint search failed to find a solution within the search range for arc of cell:'DFM1RA_st', r_pin:'CK', r_pin dir:'r', pin:'D', pin dir:'f', type:'hold_rising fall_constraint', vector:'RFxx'. This cell will be marked as failed and the constraint data will be set to: 1.0 (see constraint_failed_value). To debug, review the saved simulation results for deck: hold_6. Possible causes include: 'constraint_delay_degrade' too large; 'constraint_delay_degrade_abstol' too large; 'constraint_check_final_state_threshold' too large; estimated search range too small (see constraint_search_bound). Modify the constraint parameters and rerun.
请问有人见过这样的问题吗,按照它提示的'constraint_delay_degrade','constraint_delay_degrade_abstol'改的很小了,也是不对,不知道什么原因?
 楼主| 发表于 2019-3-16 15:12:26 | 显示全部楼层
回复 1# 亭ting
   你好,我现在遇到了跟你这个一样的问题,之前都是生成组合逻辑没问题,现在加了一触发器就这样了,请问你是怎么解决的呐?
GMT+8, 2025-10-4 13:50 , Processed in 0.010523 second(s), 3 queries , Gzip On, Redis On.
