查看: 5819|回复: 2
[求助] cadence使用过程中的问题
发表于 2018-11-22 10:45:31 | 显示全部楼层 |阅读模式
Loading monte.cxt
      ...unsuccessful.
Delete psf data in /home/WXL/simulation/NAND-test/spectre/schematic/psf.
generate netlist...
Begin Incremental Netlisting Nov 22 10:41:27 2018
WARNING (OSSHNL-143): Incremental netlisting is not possible since the global map file '/home/WXL/simulation/NAND-test/spectre/schematic/netlist/ihnl/globalmap', could
not be opened in the read mode for IHNL version number comparison. Therefore
re-netlisting the entire design.
Netlist Error: Missing parameter 'F1' in V0
Netlist Error: Missing parameter 'N1' in V0
Netlist Error: Missing parameter 'F2' in V0
Netlist Error: Missing parameter 'N2' in V0
Netlist Error: Missing parameter 'F3' in V0
Netlist Error: Missing parameter 'N3' in V0
End netlisting Nov 22 10:41:28 2018
ERROR (OSSHNL-514): Netlist generation failed because of the errors reported above. The netlist might not have been generated at all, or the generated netlist could be corrupt. Fix the reported errors and regenerate the netlist.
      ...unsuccessful.
发表于 2018-11-27 10:10:50 | 显示全部楼层
V0这个期间的参数没有设置?
发表于 2018-11-28 10:08:10 | 显示全部楼层
这不是变量没有设置初始值么
GMT+8, 2025-12-28 12:07 , Processed in 0.014913 second(s), 3 queries , Gzip On, Redis On.
