查看: 3943|回复: 6
[求助] AD DA 如何透过hspice FFT 算ENOB ??
发表于 2018-11-22 07:11:12 | 显示全部楼层 |阅读模式
如何透过FFT 算AD   ENOB  ??
一般说  fs/N  =  fin M  .  N = fft取多少点至少 2^N  ,    M 奇数周期
fs =4M
sin ->  ideal ADC -> ideal DAC
adc use 10bit  ,  hspice simulation
对 dac out  对输入FIN 做 fft ,  输出会 1.5v 上下 sine
但使用 sandwork  waveform tool  ADCtoolbox 要如何算出     ENOB ?
thank you .
`define adc_size 10
`include "discipline.h"
`include "constants.h"
module ideal_adc(in,clk,out);
input in,clk;
output [0:`adc_size-1] out;
voltage in,clk,out;
// parameter integer adc_size = 3 from [1:inf);
parameter real fullscale = 3.3;
parameter real delay_ = 0, trise = 10n, tfall = 10n;
parameter real clk_vth = 1.5;
parameter real out_high = 1, out_low = 0 from (-infut_high);
real sample,thresh;
real result[0:`adc_size-1];
integer i;
analog
begin
   @(cross(V(clk)-clk_vth, +1))
   begin
     sample = V(in);
     thresh = fullscale/2;
     for(i=adc_size-1;i>=0;i=i-1)
     begin
       if (sample > thresh)
       begin
         result[i] = out_high;
         sample = sample - thresh;
       end
       else result[i] = out_low;
       sample = 2*sample;
     end
   end
   for(i=`adc_size-1;i>=0;i=i-1)
      V(out) <+ transition(result,delay_,trise,tfall);
end
endmodule
`define dac_size 10
module ideal_dac(in,out);
input [0:`dac_size-1] in;
output out;
voltage in,out;
parameter real dac_size = 2 from (1:inf);
parameter vth = 2.5;
parameter real trise = 0 from [0:inf);
parameter real tfall = 0 from [0:inf);
real code;
integer pow2 [0:`dac_size];
analog
begin
   @(initial_step)
     for (i=0;i<=`dac_size;i=i+1)
          pow2[i] = pow(2,i);
   code = 0;
   for (i=0;i<`dac_size;i=i+1)
     code = code + (V(in[i]) > vth) ? pow2[i] : 0;
   V(out) <+ transition(code/pow2[`dac_size],0,trise,tfall);
end
endmodule
发表于 2018-11-22 08:19:57 | 显示全部楼层
回复 1# peterlin2010
可以把波形保存成csv文件(默认精度好像只有四位,需要改高), 然后用下面这个Matlab程序处理:https://secure.engr.oregonstate.edu/wiki/ams/index.php/Matlab/PrettyFFT
 楼主| 发表于 2018-11-22 20:54:12 | 显示全部楼层
hspice   波形保存成csv文件 ??
hspice fft 要如何直接算? spiceExplorer ADCtool 到底如何用?
不靠  matlab 方式
发表于 2018-11-23 02:43:44 | 显示全部楼层
回复 2# iamshuang2013
看错了,Hspice没用过,不知道能不能导出数据。如果能导出的话,感觉用Matlab处理跟灵活一些,网上有很多函数可以调用。
 楼主| 发表于 2018-11-24 11:38:44 | 显示全部楼层
回复  iamshuang2013
看错了,Hspice没用过,不知道能不能导出数据。如果能导出的话,感觉用Matlab处理 ...
iamshuang2013 发表于 2018-11-23 02:43
    用.meas的指令将读到的数值丢给mathlab去执行,
记得要把时间去掉
chip123
可以  xxx(:,1)=[ ];
=>  读取时就会清掉第一行时间
load my_xy.dat;     %  read data into the my_xy matrix
x = my_xy(:,1);     %  copy first column of my_xy into x
y = my_xy(:,2);     %  and second column into y
或可以连时间一起复制没有关系,只要丢入matlab内存成矩阵,
再打开存好的矩阵把你的电压那列整列复制,再存成另一个矩阵,就可以只分析电压罗!
fft 发现 eetop
http://bbs.eetop.cn/viewthread.php?tid=702851
edaboard find
np*Tck=Tsig*N
N =odd   np=2^n
.option  fft_accurate
.param N=99
.param np=1024
.param fck=125E6
.param Tck=1/fck
.param starttime=100n
.param stoptime='starttime+np*Tck'
.fft v(out) np=1024 from=starttime to=stoptime
发表于 2018-11-25 10:05:05 | 显示全部楼层
回复 5# peterlin2010
Cool!
 楼主| 发表于 2018-11-25 11:08:16 | 显示全部楼层
回复  peterlin2010
Cool!
iamshuang2013 发表于 2018-11-25 10:05
    customwave  adcTool 有没有人会使用 ?
如果 能直接用HSPICE  + FFT  就不须要 matlab
GMT+8, 2025-12-24 12:55 , Processed in 0.017163 second(s), 3 queries , Gzip On, Redis On.
