查看: 1933|回复: 0
[求职] Sr. or Front End Design Engineer
发表于 2018-11-19 14:28:43 | 显示全部楼层 |阅读模式
有兴趣的朋友请发简历至nina.zhang@amd.com
邮件标题: 姓名+应聘职位+eetop, 谢谢
RESPONSIBILITIES:
Understand thearchitecture of the graphics IP and functional block being designed
Build C/C++ model forsimulation
Build test bench andmonitors for DUT
Compose test plan andvalidation vectors to ensure functional completeness
Debugfunction/performance bugs of graphics IP
Work with globalFront-End design team and physical design team for large scale ASIC chipphysical implementation
Focus on physicaldesign of deep sub-micron GPU chips including block level (full chip) floorplanning, timing closure, place&route, physical verification etc
REQUIREMENTS:
Have in depthknowledge of entire design process from Design specification, definingarchitecture, micro-architecture, RTL design and functional verification,synthesis, Physical Design, Timing closure, Tape-out, and post-Si debug.
Have hands-onexperience in Chiplevel Design/Integration activities.
Some Physical Designexposure required.
Perform Synthesis andnetlisting tasks such as SDC Development, Scan Insertion, ECO implementation,Formal Verification, etc.
Some exposure to DFTis a strong plus.
Work with PhysicalDesign team on Floor Plan, budgeting, timing closure, Signal Integrity, ECOflows, Power analysis, IO PAD placement, etc.
Should have expertisein: Cadence RTL Compiler, Design Compiler, PrimeTime, Conformal LEC. Goodknowledge of datapath compilers is required.
Expertise in Perl andTcl is a must.
Knowledge of chip businterfaces such as AHB and various standard peripherals & interfaces is a plus.
Should be able to workclosely with RTL Designers and Backend Physical Design teams across multiplesites.
Must have goodcommunication & Analytical thinking skills.
Should haveproficiency in flow development and scripting.
Should be able to Leada team, and provide Technical mentoring and guidance to junior engineers.
EDUCATION:
Master with at least 5years or Bachelor with at least 8 years working experience in ASIC area
GMT+8, 2025-9-19 04:45 , Processed in 0.018489 second(s), 4 queries , Gzip On, Redis On.
