查看: 2940|回复: 4
[求助] 求助
发表于 2018-11-9 15:48:44 | 显示全部楼层 |阅读模式
在使用cadence ic616跑spectre仿真时,报错Error found by spectre during AHDL read-in
报错截图如下:
 楼主| 发表于 2018-11-9 15:51:56 | 显示全部楼层
自己顶一下
 楼主| 发表于 2018-11-9 15:55:20 | 显示全部楼层
报错文字:
Error found by spectre during AHDL read-in.
    ERROR (VACOMP-1010): Could not open ahdlcmi module library
        input.ahdlSimDB/bsource.va.bsource_4.ahdlcmi/Linux-64/obj/optimize/5.0/libahdlcmi.so
                /lib64/libc.so.6: version `GLIBC_2.14' not found (required by
        input.ahdlSimDB/bsource.va.bsource_4.ahdlcmi/Linux-64/obj/optimize/5.0/libahdlcmi.so)
Notice from spectre during circuit read-in.
    38 `voltage source' are shorted because of their small value.
    2168 `resistor' are shorted because of their small value.
Time for Elaboration: CPU = 23.5444 s, elapsed = 23.7119 s.
Time accumulated: CPU = 32.2971 s, elapsed = 32.4499 s.
Peak resident memory used = 1.43 Gbytes.
发表于 2018-11-10 10:31:27 | 显示全部楼层
 楼主| 发表于 2018-11-13 08:30:36 | 显示全部楼层
回复 4# 122013137
   是的  请问您知道怎么解决吗?
GMT+8, 2025-12-18 12:57 , Processed in 0.015659 second(s), 5 queries , Gzip On, Redis On.
