查看: 3339|回复: 4
[求助] Stream in Multipath打散问题
发表于 2018-11-7 14:56:21 | 显示全部楼层 |阅读模式
Stream in一个GDS后,multipath会被打散,各位有方法解决这个问题吗?
stream out stream in都是在IC616下进行的,是不同Fab的工艺。下面是我stream out时的设置,应该没什么问题:
发表于 2018-11-7 16:24:33 | 显示全部楼层
同样求解!
发表于 2018-11-7 16:50:26 | 显示全部楼层
帮顶一下,我也想知道stream out后可不可以保存下来
发表于 2018-11-8 14:14:31 | 显示全部楼层
顶一下
发表于 2018-11-9 13:50:13 | 显示全部楼层
There is no way to maintain its structure without flatten due to its data structure's characteristics
If you use the Multi-Path to drawing GuardRing in your layout . Only you can use the Fluid GuardRing to achieve this goal  Since you define it in your tech-file
GMT+8, 2025-12-29 17:28 , Processed in 0.018263 second(s), 5 queries , Gzip On, Redis On.
