查看: 3551|回复: 12
[资料] An 8 bit current steering DAC for offset compensation purposes in sensor arrays
发表于 2018-10-25 14:13:16 | 显示全部楼层 |阅读模式
G. Bertotti1,2, A. Laifi1, E. Di Gioia1, M. Masoumi1, N. Dodel1, E. F. Scarselli2, and R. Thewes1
1Chair of Sensor and Actuator Systems, TU Berlin, Berlin, Germany
2ARCES, University of Bologna, Bologna, Italy
Abstract. An 8 bit segmented current steering DAC is presented for the compensation of mismatch of sensors with current output arranged in a large arrays. The DAC is implemented in a 1.8V supply voltage 180 nm standard CMOS technology. Post layout simulations reveal that the design target concerning a sampling frequency of 2.6MHz is exceeded, worst-case settling time equals 60.6 ns. The output current range is 0–10 μA, which translates into an LSB of 40 nA. Good linearity is achieved, INL<0.5 LSB and DNL<0.4 LSB, respectively. Static power consumption with the outputs operated at a voltage of 0.9V is approximately 10μW. Dynamic power, mainly consumed by switching activity of the digital circuit parts, amounts to 100μW at 2.6MHz operation frequency. Total area is 38.6×2933.0 μm2
An 8 bit current steering DAC for offset.pdf
1.19 MB, 下载次数: 129 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2018-10-25 16:22:59 | 显示全部楼层
Good.
发表于 2018-10-25 22:56:31 | 显示全部楼层
thanks
发表于 2018-10-26 00:37:27 | 显示全部楼层
非常感謝~~~
发表于 2018-10-31 11:26:17 | 显示全部楼层
look look!
发表于 2018-11-1 08:46:38 | 显示全部楼层
谢谢分享
发表于 2018-11-1 09:22:50 | 显示全部楼层
Xie Xie
发表于 2018-11-5 20:08:32 | 显示全部楼层
回复 1# hi_china59
    thanks for sharing
发表于 2019-3-13 14:03:37 | 显示全部楼层
thanks
发表于 2019-4-4 22:45:00 | 显示全部楼层
謝謝分享
GMT+8, 2025-11-7 11:55 , Processed in 0.020916 second(s), 4 queries , Gzip On, Redis On.
