查看: 14344|回复: 49
ebook: Fundamentals of Spectrum Analysis
发表于 2007-11-6 17:25:02 | 显示全部楼层 |阅读模式
Christoph Rauscher
Table of contents
1 INTRODUCTION 9
2 SIGNALS 10
2.1 Signals displayed in time domain 10
2.2 Relationship between time and frequency domain 11
3 CONFIGURATION AND CONTROL ELEMENTS OF A SPECTRUM ANALYZER 19
3.1 Fourier analyzer (FFT analyzer) 19
3.2 Analyzers operating according to the heterodyne principle 29
3.3 Main setting parameters 32
4 PRACTICAL REALIZATION OF AN ANALYZER OPERATING ON THE HETERODYNE PRINCIPLE 34
4.1 RF input section (frontend) 34
4.2 IF signal processing 46
4.3 Determination of video voltage and video filters 58
4.4 Detectors 64
4.5 Trace processing 77
4.6 Parameter dependencies 80
4.6.1 Sweep time, span, resolution and video bandwidths 80
4.6.2 Reference level and RF attenuation 84
4.6.3 Overdriving 90
5 PERFORMANCE FEATURES OF SPECTRUM ANALYZERS 100
5.1 Inherent noise 100
5.2 Nonlinearities 107
5.3 Phase noise (spectral purity) 119
5.4 1 dB compression point and maximum input level 125
5.5 Dynamic range 130
5.6 Immunity to interference 142
5.7 LO feedthrough 145
5.8 Filter characteristics 146
5.9 Frequency accuracy 147
5.10 Level measurement accuracy 148
5.10.1 Error components 149
5.10.2 Calculation of total measurement uncertainty 156
5.10.3 Error due to low signal-to-noise ratio 164
5.11 Sweep time and update rate 167
6 FREQUENT MEASUREMENTS AND ENHANCED FUNCTIONALITY 170
6.1 Phase noise measurements 170
6.1.1 Measurement procedure 170
6.1.2 Selection of resolution bandwidth 173
6.1.3 Dynamic range 175
6.2 Measurements on pulsed signals 180
6.2.1 Fundamentals 181
6.2.2 Line and envelope spectrum 186
6.2.3 Resolution filters for pulse measurements 191
6.2.4 Analyzer parameters 192
6.2.5 Pulse weighting in spurious signal measurements 194
6.2.5.1 Detectors, time constants 195
6.2.5.2 Measurement bandwidths 199
6.3 Channel and adjacent-channel power measurement 199
6.3.1 Introduction 199
6.3.2 Key parameters for adjacent-channel power measurement 202
6.3.3 Dynamic range in adjacent-channel power measurements 203
6.3.4 Methods for adjacent-channel power measurement using a spectrum analyzer 204
6.3.4.1 Integrated bandwidth method 204
6.3.4.2 Spectral power weighting with modulation filter (IS-136, TETRA, WCDMA) 208
6.3.4.3 Channel power measurement in time domain 210
6.3.4.4 Spectral measurements on TDMA systems 211
MEASUREMENT TIPS
Measurements in 75 Ω system 35
Measurement on signals with DC component 39
Maximum sensitivity 106
Identification of intermodulation products 117
Improvement of input matching 155
REFERENCES 214
THE CURRENT SPECTRUM ANALYZER
MODELS FROM ROHDE & SCHWARZ 216
Fundamentals of spectrum analysis.pdf
3.08 MB, 下载次数: 375 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2007-11-6 22:19:20 | 显示全部楼层
have a look
发表于 2007-11-7 17:19:03 | 显示全部楼层
收了...很需要這個!!!
发表于 2008-1-13 19:07:55 | 显示全部楼层
好书,收下了,谢谢楼主!
发表于 2008-1-14 09:15:21 | 显示全部楼层
好书,谢谢了!
发表于 2008-1-14 12:54:11 | 显示全部楼层
Thank you very much!
发表于 2008-1-16 09:25:52 | 显示全部楼层
谢谢共享!好东西啊!
发表于 2008-1-27 01:12:33 | 显示全部楼层
好詳細的教學書
頂一下
发表于 2008-4-13 16:35:03 | 显示全部楼层
thanks~
发表于 2008-4-17 11:02:12 | 显示全部楼层
谢谢楼主分享
GMT+8, 2025-12-20 04:14 , Processed in 0.025211 second(s), 6 queries , Gzip On, Redis On.
