查看: 16256|回复: 98
The Electrical Engineering Handbook
发表于 2007-10-13 23:42:51 | 显示全部楼层 |阅读模式
1 Passive Components M. Pecht, P. Lall, G. Ballou, C. Sankaran, N. Angelopoulos   Resistors•Capacitors and Inductors•Transformers•Electrical Fuses
2 Voltage and Current Sources R.C. Dorf, Z. Wan, C.R. Paul, J.R. Cogdell   Step, Impulse, Ramp, Sinusoidal, Exponential, and DC Signals•Ideal and Practical Sources•Controlled Sources
3 Linear Circuit Analysis M.D. Ciletti, J.D. Irwin, A.D. Kraus, N. Balabanian, T.A. Bickart, S.P. Chan, N.S. Nise   Voltage and Current Laws•Node and Mesh Analysis•Network Theorems&#8226ower and Energy•Three-Phase Circuits•Graph Theory•Two Port Parameters and Transformations
4 Passive Signal Processing W.J. Kerwin   Low-Pass Filter Functions•Low-Pass Filters•Filter Design
5 Nonlinear Circuits J.L. Hudgins, T.F. Bogart, Jr., K. Mayaram, M.P. Kennedy, G. Kolumbán   Diodes and Rectifiers•Limiters•Distortion•Communicating with Chaos
6 Laplace Transform R.C. Dorf, Z. Wan, D.E. Johnson   Definitions and Properties•Applications
7 State Variables: Concept and Formulation W.K. Chen   State Equations in Normal Form•The Concept of State and State Variables and Normal Tree•Systematic Procedure in Writing State Equations•State Equations for Networks Described by Scalar Differential Equations•Extension to Time-Varying and Nonlinear Networks
8 The z-Transform R.C. Dorf, Z. Wan   Properties of the  z -Transform•Unilateral  z -Transform• z -Transform Inversion•Sampled Data
9T- P  Equivalent Networks Z. Wan, R.C. Dorf   Three-Phase Connections•Wye  ⇔  Delta Transformations
10 Transfer Functions of Filters R.C. Dorf, Z. Wan   Ideal Filters•The Ideal Linear-Phase Low-Pass Filter•Ideal Linear-Phase Bandpass Filters•Causal Filters•Butterworth Filters•Chebyshev Filters
11 Frequency Response P. Neudorfer   Linear Frequency Response Plotting•Bode Diagrams•A Comparison of Methods
12 Stability Analysis F. Szidarovszky, A.T. Bahill   Using the State of the System to Determine Stability•Lyapunov Stability Theory•Stability of Time-Invariant Linear Systems•BIBO Stability&#8226hysical Examples
13 Computer Software for Circuit Analysis and Design J.G. Rollins, P. Bendix   Analog Circuit Simulation&#8226arameter Extraction for Analog Circuit Simulation
14 Digital Signal Processing W. K. Jenkins, A.D. Poularikas, B.W. Bomar, L.M. Smith, J.A. Cadzow   Fourier Transforms•Fourier Transforms and the Fast Fourier Transform•Design and Implementation of Digital Filters•Signal Restoration
15 Speech Signal Processing S. McClellan, J.D. Gibson, Y. Ephraim, J.W. Fussell, L.D. Wilcox, M.A. Bush, Y. Gao, B. Ramabhadran, M. Picheny   Coding, Transmission, and Storage•Speech Enhancement and Noise Reduction•Analysis and Synthesis•Speech Recognition•Large Vocabulary Continuous Speech Recognition
16 Spectral Estimation and Modeling S.U. Pillai, T.I. Shim, S.N. Batalama, D. Kazakos, F. Daum   Spectral Analysis•Parameter Estimation•Kalman Filtering
17 Multidimensional Signal Processing E.J. Delp, J. Allebach, C.A. Bouman, S.A. Rajala, N.K. Bose, L.H. Sibul, W. Wolf, Y-Q Zhang   Digital Image Processing•Video Signal Processing•Sensor Array Processing•Video Processing Architectures•MPEG-4 Based Multimedia Information System
18 VLSI for Signal Processing K.K. Parhi, R. Chassaing, B. Bitler   Special Architectures•Signal Processing Chips and Applications
19 Acoustic Signal Processing J. Schroeter, S.K. Mehta, G.C. Carter   Digital Signal Processing in Audio and Electroacoustics•Underwater Acoustical Signal Processing
20 Artificial Neural Networks J.C. Principe   Definitions and Scope•Multilayer Perceptrons•Radial Basis Function Networks•Time Lagged Networks•Hebbian Learning and Principal Component Analysis Networks•Competitive Learning and Kohonen Networks
21 Computing Environments for Digital Signal Processing D.M. Etter   MATLAB Environment•Example 1: Signal Analysis•Example 2: Filter Design and Analysis• Example 3: Multirate Signal Processing
22 Semiconductors G.S. Gildenblat, B. Gelmont, M. Milkovic, A. Elshabini-Riad, F.W. Stephenson, I.A. Bhutta, D.C. Look   Physical Properties•Diodes•Electrical Equivalent Circuit Models and Device Simulators for Semiconductor Devices•Electrical Characterization of Semiconductors
23 Semiconductor Manufacturing H.G. Parks, W. Needham, S. Rajaram, C. Rafferty   Processes•Testing•Electrical Characterization of Interconnections•Process Modeling and Simulation
24 Transistors S. Soclof, J. Watson, J.R. Brews   Junction Field-Effect Transistors•Bipolar Transistors•The Metal-Oxide Semiconductor Field-Effect Transistor (MOSFET)
25 Integrated Circuits J.E. Brewer, M.R. Zargham, S. Tragoudas, S. Tewksbury   Integrated Circuit Technology•Layout, Placement, and Routing•Application-Specific Integrated Circuits
26 Surface Mount Technology G.R. Blackwell   Definition and Considerations • SMT Design, Assembly, and Test Overview • Surface Mount Device (SMD) Definitions•Substrate Design Guidelines•Thermal Design Considerations• Adhesives•Solder Paste and Joint Formation•Parts Inspection and Placement•Reflow Soldering•Cleaning•Prototype Systems
27 Operational Amplifiers E.J. Kennedy, J.V. Wait   Ideal and Practical Models•Applications
28 Amplifiers G.L. Carpenter, J. Choma, Jr . Large Signal Analysis•Small Signal Analysis
29 Active Filters R.E. Massara, J.W. Steadman, B.M. Wilamowski, J.A. Svoboda   Synthesis of Low-Pass Forms•Realization•Generalized Impedance Converters and Simulated Impedances
30 Power Electronics K. Rajashekara, A.K.S. Bhat, B.K. Bose   Power Semiconductor Devices•Power Conversion•Power Supplies•Converter Control of Machines
31 Optoelectronics J. Hecht, L.S. Watkins, R.A. Becker   Lasers•Sources and Detectors•Circuits
32 D/A and A/D Converters S.A.R. Garrod   D/A and A/D Circuits
33 Thermal Management of Electronics A. Bar-Cohen   Heat Transfer Fundamentals•Chip Module Thermal Resista34 Digital and Analog Electronic Design Automation A. Dewey   Design Entry•Synthesis•Verification•Physical Design䉔
[ 本帖最后由 gtliu 于 2007-11-4 16:59 编辑 ]
 楼主| 发表于 2007-10-14 15:42:24 | 显示全部楼层
[ 本帖最后由 gtliu 于 2007-11-7 09:54 编辑 ]
the electrical engineering handbook.part01.rar
3.81 MB, 下载次数: 84 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2007-10-14 15:47:33 | 显示全部楼层
[ 本帖最后由 gtliu 于 2007-11-7 13:13 编辑 ]
the electrical engineering handbook.part02.rar
3.81 MB, 下载次数: 75 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2007-10-14 15:51:11 | 显示全部楼层
[ 本帖最后由 gtliu 于 2007-11-7 13:24 编辑 ]
the electrical engineering handbook.part03.rar
3.81 MB, 下载次数: 52 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2007-10-14 15:53:21 | 显示全部楼层
[ 本帖最后由 gtliu 于 2007-11-7 13:28 编辑 ]
the electrical engineering handbook.part04.rar
3.81 MB, 下载次数: 65 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2007-10-14 15:58:00 | 显示全部楼层
[ 本帖最后由 gtliu 于 2007-11-7 13:30 编辑 ]
the electrical engineering handbook.part05.rar
3.81 MB, 下载次数: 71 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2007-10-14 16:00:27 | 显示全部楼层
[ 本帖最后由 gtliu 于 2007-11-7 13:31 编辑 ]
the electrical engineering handbook.part06.rar
3.81 MB, 下载次数: 73 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2007-10-14 16:01:54 | 显示全部楼层
[ 本帖最后由 gtliu 于 2007-11-7 13:35 编辑 ]
the electrical engineering handbook.part07.rar
3.81 MB, 下载次数: 72 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2007-10-14 16:14:10 | 显示全部楼层
[ 本帖最后由 gtliu 于 2007-11-7 14:12 编辑 ]
the electrical engineering handbook.part08.rar
3.81 MB, 下载次数: 82 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2007-10-14 16:22:31 | 显示全部楼层
[ 本帖最后由 gtliu 于 2007-11-7 14:28 编辑 ]
the electrical engineering handbook.part09.rar
3.81 MB, 下载次数: 70 , 下载积分: 资产 -2 信元, 下载支出 2 信元
GMT+8, 2025-12-25 11:39 , Processed in 0.024915 second(s), 4 queries , Gzip On, Redis On.
