楼主: kooba
hspice和hsim有什么区别了?
发表于 2010-4-16 22:05:35 | 显示全部楼层
hsim is mix-mode simulator some block
can use behavior description
发表于 2010-8-26 11:31:05 | 显示全部楼层
hsim仿真memory不错,但是如果不做精度设置,在仿真analog circuit时精度会有问题,甚至可能出现功能上的错误。
发表于 2010-9-16 11:34:31 | 显示全部楼层
还好 两个软件有差别
发表于 2010-9-16 13:52:03 | 显示全部楼层
hsim速度快,容量大,但精度低。
hspice速度慢,容量小,但精度高。
发表于 2010-10-3 15:16:11 | 显示全部楼层
顶你拉拉拉拉了
发表于 2010-11-30 19:32:52 | 显示全部楼层
thanks
发表于 2011-10-23 20:16:04 | 显示全部楼层
hsim  和 hspice  是同一家公司的产品???不是吧  hsim  不是日本的么?
听说是日本的 我才没用的
发表于 2012-1-4 13:33:55 | 显示全部楼层
多谢多谢!!!!!!!!!!!!1
发表于 2012-1-4 18:47:48 | 显示全部楼层
Hsim is from Nassda which was acquired by Synopsys 6~8 years ago.
Nassda was found by Chinese guy. After synopsys acquisition, the original founder of Nassda creates Spice-explorer which is a very popular and easy-to-use waveform viewer, then thsi company was acquired by Synopsys again.
Hsim can be used to simulate SDM audiocodec up to 100dB without any accuracy issue, this had been verified in  real silicon measurement.
To reach the accuracy you want, the option selection/setting is key to trade-off speed/accuracy.
发表于 2012-1-11 16:07:14 | 显示全部楼层
都是synopsys公司的
GMT+8, 2025-11-5 03:58 , Processed in 0.017141 second(s), 3 queries , Gzip On, Redis On.
