查看: 3000|回复: 0
与CC有关的文档目录
发表于 2007-9-24 16:11:06 | 显示全部楼层 |阅读模式
希望对研究CC的人有点用
CEA Standards
EIA-608-B                Line 21 Data Services                                October 2000
EIA-708-B                Digital Television Closed Captioning         December 1999
EIA-CEB8                Consideration of EIA-608-B Data Within        October 2000
                        The DTV (EIA-708-B) Construct
Available through Global Engineering Documents
<http://www.global.ihis.com>
FCC Rules
47 CFR Part 15.119        Decoder Requirements, Analog Television
47 CFR Part 15.122        Decoder Requirements, Digital Television
<http://www.fcc.gov/oet/info/rules/part15/part15_jan8_01.pdf>
47 CFR Part 79                Programming Requirements
<http://www.fcc.gov/cib/dro/ccrules.html>
FCC FAQ on Closed Captioning
<http://www.fcc.gov/cib/dro/ccfactsh.html>
ATSC Standards
A/53                        ATSC Digital Television Standard                September 1995
A/65                        PSIP         (Rev. A and Amendment No.1)        May 2000
<http://www.atsc.org/Standards/stan_rps.html>
SMPTE Standards
SMPTE 333M-1999        Television - DTV Closed-Caption Server to Encoder Interface (24.00)
SMPTE 334M-2000        Television - Vertical Ancillary Data Mapping for
Bit-Serial Interface (20.00)
SMPTE 341M-2000        Television - Format for Non-PCM Audio and Data in an AES3 -- Captioning Data Type (15.00)
        (also see SMPTE 337M through 340M)
Contact SMPTE at  (914 ) 761 - 1100
GMT+8, 2025-12-14 04:33 , Processed in 0.014143 second(s), 5 queries , Gzip On, Redis On.
