查看: 1969|回复: 0
why my cadence spectre doesn't work as this
发表于 2018-9-15 23:04:21 | 显示全部楼层 |阅读模式
spectre doesn't work with error:
ERROR (ADE-3036): Errors encountered during simulation. The simulator run log has not been generated.
        Possible cause could be an invalid command line option for the version of the simulator
        you are running. Choose Setup->Environment and verify that the command line options
        specified in the userCmdLineOption field are supported for the simulator.
        Alternatively, run the simulator standalone using the runSimulation file in the netlist
        directory to know the exact cause of the error.
GMT+8, 2025-12-29 06:28 , Processed in 0.012192 second(s), 4 queries , Gzip On, Redis On.
