查看: 11743|回复: 38
[资料] New UVM 1800.2 Cookbook
发表于 2018-9-11 10:34:18 | 显示全部楼层 |阅读模式
Mentor家的Verification Academy发布了最新版的UVM Cookbook,给大家分享一下。 uvm-cookbook.pdf (8.36 MB , 下载次数: 294 )
This newly-updated (2018) version conforms to the IEEE 1800.2 UVM Standard and promotes an emulation-friendly UVM testbench architecture that promotes reuse of your UVM environment as your project moves from simulation to emulation and beyond.
This new cookbook architectural change is to recommend the use of “splittransactors” where, instead of a driver/monitor component having a reference toa pin-level SystemVerilog interface, the transactor will have a reference to a“BFM interface” that supports a set of transaction-level methods called fromthe transactor. In addition to the architecture update, we have made thefollowing changes to the Cookbook:
  • Added     "UVM Basics" Introduction section
  • Streamlined     "Testbench Architecture" chapter
  • Some     material moved to "UVM Basics"
  • Focused on     emulation-friendly architecture
  • Rewrote     and streamlined "DUT-Testbench Connections"
  • Added     "UVM Messaging" chapter
  • Updated     "Register Abstraction Layer" chapter to follow     1800.2
  • Updated     "Testbench Acceleration" chapter
  • Updated     "UVM Connect" chapter
顺带将IEEE 1800.2 UVM Standard也分享给大家。
UVM_1800.2-2017.pdf (4.01 MB , 下载次数: 220 )
发表于 2018-9-11 12:43:50 | 显示全部楼层
thanks for sharing
发表于 2018-9-11 13:01:23 | 显示全部楼层
thanks
发表于 2018-9-11 19:19:40 | 显示全部楼层
Thanks for your sharing
发表于 2018-9-11 19:57:52 | 显示全部楼层
谢谢分享
发表于 2018-9-11 21:29:23 | 显示全部楼层
thankyou
发表于 2018-9-19 19:48:52 | 显示全部楼层
很棒的分享,非常感谢您提供最好的文档!
发表于 2018-9-21 21:30:32 | 显示全部楼层
刚好要找这个
非常感谢分享
发表于 2018-9-22 10:16:25 | 显示全部楼层
thanks for sharing.
发表于 2018-9-25 17:03:51 | 显示全部楼层
thanks
GMT+8, 2025-12-18 18:24 , Processed in 0.019934 second(s), 4 queries , Gzip On, Redis On.
