查看: 5242|回复: 6
[求助] cadence设计中怎么求mos管的μncox和μpcox?
发表于 2018-8-31 09:11:42 | 显示全部楼层 |阅读模式
section ss
parameters
+toxn = 10e-10
vthn = 1.52e-1
xln = 1.84e-7
+xwn = -1e-7
cjn =4.35e-5
cjswn = 3.6489e-11
+cgdon = 2e-11
cgson = 2e-11
cjswgn = 2.00e-15
+toxp = 10e-10
vthp =-1.9e-1
xlp =7.7e-8
+xwp = -1.0e-7
cjp =8.208e-5
cjswp = 4.177e-11
+cgdop = 1.0e-11
cgsop = 1.0e-11
cjswgp = 2e-15
+toxln = 10e-10
vthln =0.1
xlln = 0.06e-6
+xwln = -0.08e-6
cjln= 4.35e-05
cjswln = 3.65e-11
+cgdoln = 2.00e-11
cgsoln = 2.00e-11
cjswgln = 2.00e-15
+toxlp = 10e-10
vthlp = -0.1
xllp= 0.06e-6
+xwlp = -0.08e-6
cjlp= 8.2e-5
cjswlp = 4.10e-11
+cgdolp = 1e-11
cgsolp = 1e-11
cjswglp = 2e-15
include "s06mixddct10v04.scs"section=spectrebase
include "s06mixddct10v04.scs"section=deptt
include "s06mixddct10v04.scs"section=bjt
endsection ss
csmc 0.6um的工艺参数,怎么从这些参数里求出 μncox  和  μpcox??
 楼主| 发表于 2018-8-31 09:14:24 | 显示全部楼层
section ss
parameters
+toxn = 10e-10
vthn = 1.52e-1
xln = 1.84e-7
+xwn = -1e-7
cjn =4.35e-5
cjswn = 3.6489e-11
+cgdon = 2e-11
cgson = 2e-11
cjswgn = 2.00e-15
+toxp = 10e-10
vthp =-1.9e-1
xlp =7.7e-8
+xwp = -1.0e-7
cjp =8.208e-5
cjswp = 4.177e-11
+cgdop = 1.0e-11
cgsop = 1.0e-11
cjswgp = 2e-15
+toxln = 10e-10
vthln =0.1
xlln = 0.06e-6
+xwln = -0.08e-6
cjln= 4.35e-05
cjswln = 3.65e-11
+cgdoln = 2.00e-11
cgsoln = 2.00e-11
cjswgln = 2.00e-15
+toxlp = 10e-10
vthlp = -0.1
xllp= 0.06e-6
+xwlp = -0.08e-6
cjlp= 8.2e-5
cjswlp = 4.10e-11
+cgdolp = 1e-11
cgsolp = 1e-11
cjswglp = 2e-15
endsection ss
发表于 2018-8-31 17:45:46 | 显示全部楼层
spectre里有u0, cox=E*Eox/tox计算出,E为介电常数
发表于 2018-8-31 22:28:58 | 显示全部楼层
你复制的模型文件不全啊,看typical字段的迁移率和TOX描述。
 楼主| 发表于 2018-9-3 15:35:17 | 显示全部楼层
******csmc 0.6um double poly mix process hspice model********************
*it is strongly recommended you read through all the note before your   *
*simulation                                                             *
* this model card includes models of hspice version:                    *
* 1)  normal and low vth mos device model libs                          *
*     section tt    : normal and low vth mos                            *
*     section ff    : normal and low vth mos                            *
*     section fs    : normal and low vth mos                            *
*     section sf    : normal and low vth mos                            *
*     section ss    : normal and low vth mos                            *
*  each lib includes four device models,listed below:                   *
*     a)model nmos nmos :  normal vth nmos                              *
*     b)model pmos pmos :  normal vth pmos                              *
*     c)model lvn  nmos :  low vth nmos                                 *
*     d)model lvp  pmos :  low vth pmos                                 *
* 2) typical depletion mos device model:                                *
*     section deptt                                                     *
*   this lib includes two device models                                 *
*     model depn nmos :  depletion nmos                                 *
*     model depp pmos :  depletion pmos                                 *
*  3)bjt device model:                                                  *
*     section bjt    :parasitic bjt model                               *
*     there are 3 bjt models in this lib:                               *
*     a)   model pnp10:  with emitter area = 100 um^2 (10x10)           *
*     b)   model pnp20: with emitter area = 400 um^2 (20x20)            *
*     c)   model pnp5: with emitter area = 25 um^2   (5x5)              *
*         usage example: q1 nc nb ne pnp5                               *
*                                        ( use default area=1)          *
*  to use these models directly by programming in this style:           *
*     include "lib_path/libfile_name" section_name                      *
*  ex: include "/home/user/csmc/s06mixddct10v04.scs" section=tt         *
*             for typical mos device                                    *
simulator lang=spectre
library csmc
section tt
parameters
+toxn     = 0                   vthn     = 0                   xln      = 0
+xwn      = 0                   cjn      = 0                   cjswn    = 0
+cgdon    = 0                   cgson    = 0                   cjswgn  = 0
+toxp     = 0                   vthp     = 0                   xlp      = 0
+xwp      = 0                   cjp      = 0                   cjswp    = 0
+cgdop    = 0                   cgsop    = 0                   cjswgp  = 0
+toxln     = 0                  vthln     = 0                  xlln      = 0
+xwln      = 0                  cjln      = 0                  cjswln    = 0
+cgdoln    = 0                  cgsoln    = 0                  cjswgln  = 0
+toxlp     = 0                  vthlp     = 0                  xllp      = 0
+xwlp      = 0                  cjlp      = 0                  cjswlp    = 0
+cgdolp    = 0                  cgsolp    = 0                  cjswglp  = 0
include "s06mixddct10v04.scs" section=spectrebase
include "s06mixddct10v04.scs" section=deptt
include "s06mixddct10v04.scs" section=bjt
endsection tt
section ff
parameters
+toxn     = -10e-10             vthn     = -1.49e-1            xln      = -1.96e-7
+xwn      = 1e-7                cjn      = -4.35e-5            cjswn    = -3.6489e-11
+cgdon    = -2e-11              cgson    = -2e-11              cjswgn  = -2.00e-15
+toxp     = -10e-10             vthp     = 1.9e-1              xlp      = -1.0e-7
+xwp      = 1.0e-7              cjp      = -8.208e-5           cjswp    = -4.177e-11
+cgdop    = -1.0e-11            cgsop    = -1.0e-11            cjswgp  = -2e-15
+toxln     = -10e-10            vthln     = -0.1               xlln      = -0.06e-6
+xwln      = 0.08e-6            cjln      = -4.35e-05          cjswln    = -3.65e-11
+cgdoln    = -2.00e-11          cgsoln    = -2.00e-11          cjswgln  = -2.00e-15
+toxlp     = -10e-10            vthlp     = 0.1                xllp      = -0.06e-6
+xwlp      = 0.08e-6            cjlp      = -8.2e-5            cjswlp    = -4.10e-11
+cgdolp    = -1e-11             cgsolp    = -1e-11             cjswglp  = -2e-15
endsection ff
section fs
parameters
+toxn     = -5e-10              vthn     = -0.75e-1            xln      = -0.96e-7
+xwn      = 5e-8                cjn      = -4.35e-5            cjswn    = -3.6489e-11
+toxp     = 5e-10               vthp     = -8.31e-2            xlp      = 2.74e-8
+xwp      = -0.5e-7              cjp      = 8.208e-5            cjswp    = 4.177e-11
+cgdop    = 1.0e-11            cgsop    = 1.0e-11             cjswgp  = 2e-15
+toxln     = -5e-10            vthln     = -0.05               xlln      = -0.03e-6
+xwln      = 0.04e-6            cjln      = -4.35e-05          cjswln    = -3.65e-11
+toxlp     = 5e-10               vthlp     = -0.05            xllp      = 0.03e-6
+xwlp      = -0.04e-6            cjlp      = 8.2e-5           cjswlp    = 4.10e-11
+cgdolp    = 1e-11              cgsolp    = 1e-11             cjswglp  = 2e-15
endsection fs
section sf
parameters
+toxn     = 5e-10               vthn     = 0.75e-1             xln      = 9.4e-8
+xwn      = -5e-8               cjn      = 4.35e-5             cjswn    = 3.6489e-11
+cgdon    = 2e-11               cgson    = 2e-11               cjswgn  = 2.00e-15
+toxp     = -5e-10              vthp     = 0.95e-1              xlp      = -5.26e-8
+xwp      = 0.5e-7              cjp      = -8.208e-5            cjswp    = -4.177e-11
+toxln     = 5e-10              vthln     = 0.05               xlln      = 0.03e-6
+xwln      = -0.04e-6           cjln      = 4.35e-05          cjswln    = 3.65e-11
+cgdoln    = 2.00e-11           cgsoln    = 2.00e-11          cjswgln  = 2.00e-15
+toxlp     = -5e-10             vthlp     = 0.05             xllp      = -0.03e-6
+xwlp      = 0.04e-6            cjlp      = -8.2e-5           cjswlp    = -4.10e-11
endsection sf
section ss
parameters
+toxn     = 10e-10               vthn     = 1.52e-1            xln      = 1.84e-7
+xwn      = -1e-7               cjn      = 4.35e-5             cjswn    = 3.6489e-11
+toxp     = 10e-10              vthp     = -1.9e-1             xlp      = 7.7e-8
+xwp      = -1.0e-7              cjp      = 8.208e-5            cjswp    = 4.177e-11
+toxln     = 10e-10            vthln     = 0.1               xlln      = 0.06e-6
+xwln      = -0.08e-6            cjln      = 4.35e-05          cjswln    = 3.65e-11
+toxlp     = 10e-10            vthlp     = -0.1                xllp      = 0.06e-6
+xwlp      = -0.08e-6            cjlp      = 8.2e-5            cjswlp    = 4.10e-11
endsection ss
section spectrebase
model nmos bsim3v3
+type =n
+lmin     = 0.6e-6              lmax     = 2.0e-5              wmin     = 0.8e-6
+wmax     = 2.0e-5              version  = 3.0
+tox      = 1.25e-08+toxn       xj       = 2.5000000e-07       nch      = 1.2721000e+17
+lln      = 1.0295000           lwn      = 1.0000000           wln      = 0.9340000
+wwn      = 2.0000000           lint     = 1.5200000e-07       ll       = -3.5900000e-14
+lw       = 0.00                lwl      = 0.00                wint     = 2.0200001e-07
+wl       = -9.4300000e-14      ww       = -5.1700000e-20      wwl      = 0.00
+mobmod   = 1                   binunit  = 2                   xl       = 0.00e+00+xln
+xw       = 0.00e+00+xwn        dwg      = -2.2914280e-08      dwb      = 1.3746710e-08
+ldif     = 0.00                hdif     = 6.00e-07            rsh      = 0
+rd       = 0                   rs       = 0                   rsc      = 0
+rdc      = 0
+vth0     = 7.28e-01+vthn       k1       = 0.7409649           k2       = -1.5283380e-02
+k3       = 7.1778210           dvt0     = 14.8549000          dvt1     = 1.0209540
+dvt2     = -4.6828460e-02      dvt0w    = -8.0227880e-02      dvt1w    = 8.8635700e+04
+dvt2w    = 0.1900000           nlx      = 0.00                w0       = 1.3573220e-06
+k3b      = -4.7786870          ngate    = 1.0000000e+20
+vsat     = 7.7711460e+04       ua       = -7.4628200e-10      ub       = 2.6335220e-18
+uc       = 3.5986350e-11       rdsw     = 1.8026500e+03       prwb     = 1.9065101e-02
+prwg     = -3.4200580e-02      wr       = 0.9613520           u0       = 4.2603870e-02
+a0       = 0.4940039           keta     = -1.6965831e-02      a1       = 0.00
+a2       = 0.9900000           ags      = 1.9959440e-02       b0       = 8.6096910e-08
+b1       = -4.3232750e-07
+voff     = -9.6102280e-02      nfactor  = 1.0989590           cit      = 2.3121500e-04
+cdsc     = 4.8599650e-03       cdscb    = 9.1149930e-04       cdscd    = 0.00
+eta0     = 6.2591110e-03       etab     = -1.1673500e-02      dsub     = 0.2718996
+pclm     = 0.6415634           pdiblc1  = 9.6421800e-03       pdiblc2  = 1.5307820e-03
+pdiblcb  = -0.1822976          drout    = 0.1000000           pscbe1   = 2.7371760e+30
+pscbe2   = 4.6373430e-20       pvag     = 0.00                delta    = 1.0000000e-02
+alpha0   = 3.5e-6              beta0    = 30.0000000
+kt1      = -0.3333333          kt2      = -2.6930001e-02      at       = 1.2000000e+04
+ute      = -1.6454999          ua1      = 1.1130000e-09       ub1      = -1.0460000e-18
+uc1      = -6.6220000e-12      kt1l     = 0.00                prt      = 8.4800000e+02
+cj       = 4.35e-04+cjn        mj       = 0.4223898           pb       = 0.9590048
+cjsw     = 3.65e-10+cjswn      mjsw     = 0.1671139           pbsw     = 0.5406927
+cjswg    = 2e-14 +cjswgn       mjswg    = 0.33                pbswg    = 0.7
+cta      = 0                   ctp      = 0                   pta      = 0
+ptp      = 0                   js       = 1.00e-14            jsw      = 0.00
+n        = 1.0                 xti      = 3.0                 cgdo     = 2.00e-10+cgdon
+cgso     = 2.00e-10+cgson      cgbo     = 1.0e-13             capmod   = 2
+nqsmod   = 0                   elm      = 5                   xpart    = 1
+cgsl     = 2.0000000e-10       cgdl     = 2.0000000e-10       ckappa   = 1.9920000
+cf       = 0.00                clc      = 8.0259140e-09       cle      = 2.0475841
+dlc      = 1.5184e-07          dwc      = 2.015e-07
model pmos bsim3v3
+type = p
+wmax     = 2.0e-5              version  = 3.1
+tox      = 1.30e-08+toxp       xj       = 3.0000001e-07       nch      = 2.5099999e+16
+lln      = 0.2000000           lwn      = 1.0000000           wln      = 1.0660000
+wwn      = 2.0000000           lint     = -1.3000000e-09      ll       = -1.3500000e-10
+lw       = 0.00                lwl      = 1.4900000e-15       wint     = 2.3999999e-07
+wl       = 5.5000000e-15       ww       = -8.2200000e-20      wwl      = 0.00
+mobmod   = 1                   binunit  = 2                   xl       = 0.00e+00+xlp
+xw       = 0.00e+00+xwp        dwg      = -2.9800001e-08      dwb      = 2.0800000e-08
+rdc      = 0
+vth0     = -1.02e+00+vthp      k1       = 0.4355000           k2       = 1.2700000e-02
+k3       = 11.1944000          dvt0     = 6.4793000           dvt1     = 0.9395000
+dvt2     = 8.7300000e-03       dvt0w    = 3.7900000e-02       dvt1w    = 0.00
+dvt2w    = 0.1900000           nlx      = 0.00                w0       = 2.9399999e-07
+k3b      = -2.3515999          ngate    = 1.0000000e+20
+vsat     = 9.4300000e+04       ua       = 1.9199999e-09       ub       = 7.7500000e-19
+uc       = -5.0000000e-11      rdsw     = 3.3300000e+03       prwb     = 9.9200000e-02
+prwg     = -3.7100000e-02      wr       = 0.9804000           u0       = 1.9200001e-02
+a0       = 0.2612000           keta     = -1.4800000e-02      a1       = 0.00
+a2       = 0.4000000           ags      = 2.0000000e-02       b0       = 3.1600001e-07
+b1       = -3.0300001e-07
+voff     = -0.1054000          nfactor  = 0.8294000           cit      = 9.8500000e-04
+cdsc     = 1.0000000e-10       cdscb    = 0.00                cdscd    = 0.00
+eta0     = 0.1185000           etab     = -3.2900000e-03      dsub     = 0.5157000
+pclm     = 2.9535999           pdiblc1  = 1.0000000e-05       pdiblc2  = 1.2900000e-03
+pdiblcb  = 0.1900000           drout    = 3.0000000           pscbe1   = 3.7000000e+30
+pscbe2   = 1.0000000e-20       pvag     = 1.0000000           delta    = 1.0000000e-02
+alpha0   = 1.0e-6              beta0    = 30.0000000
+kt1      = -0.4763000          kt2      = -2.9050000e-02      at       = 1.0000000e+04
+ute      = -1.0000000          ua1      = 3.7500000e-09       ub1      = -7.1500000e-18
+uc1      = -5.0833000e-11      kt1l     = 0.00                prt      = -8.8300000e+02
+cj       = 8.21e-04+cjp        mj       = 0.5198076           pb       = 0.9180865
+cjsw     = 4.11e-10+cjswp      mjsw     = 0.2586436           pbsw     = 0.6054589
+cjswg    = 2.00e-14+cjswgp     mjswg    = 0.33                pbswg    = 0.7
+ptp      = 0                   js       = 1.00e-04            jsw      = 0.00
+n        = 1.0                 xti      = 3.0                 cgdo     = 1.00e-10+cgdop
+cgso     = 1.00e-10+cgsop      cgbo     = 1.0e-13             capmod   = 2
+cgsl     = 1.0000000e-10       cgdl     = 9.9592000e-11       ckappa   = 1.0000000
+cf       = 0.00                clc      = 5.0018750e-08       cle      = 0.8024064
+dlc      = -1.421085e-14       dwc      = 2.304e-07           vfbcv    = -1
model lvn bsim3v3
+type = n
+lmin     = 1.0e-6              lmax     = 2.0e-5              wmin     = 8.0e-7
+wmax     = 2.0e-5              tnom     = 25.0                version  = 3.2
+tox      = 1.25e-08+toxln      xj       = 1.0000000e-07
+nch      = 7.1525000e+16       lln      = 1.0000000           lwn      = 1.0000000
+wln      = 1.0000000           wwn      = 1.0000000           lint     = 1.0337500e-07
+ll       = -3.7391000e-14      lw       = -1.1304819e-13      lwl      = -1.6379501e-20
+wint     = 2.0677000e-07       wl       = 4.8710700e-15       ww       = -6.2206650e-14
+wwl      = -1.5963582e-19      mobmod   = 1                   binunit  = 2
+xl       = 0.00e+00+xlln        xw       = 0.00e+00+xwln        dwg      = -1.7443986e-08
+dwb      = 1.3401290e-08
+ldif     = 0.00                hdif     = 6.00e-07            rsh      = 69.48
+rdc      = 0
+vth0     = 3.57e-01+vthln      pvth0    = 2.1771500e-14       k1       = 0.5907000
+k2       = -2.6599987e-04      k3       = 3.2682290           dvt0     = 1.6550127
+dvt1     = 0.4458654           dvt2     = -0.1236620          dvt0w    = -0.3401813
+dvt1w    = 2.4880463e+06       dvt2w    = 0.2375000           nlx      = 1.4412889e-07
+w0       = 1.0198416e-10       k3b      = -2.2018001          ngate    = 1.0000000e+23
+vfb      = -0.9709756
+vsat     = 7.8906000e+04       pvsat    = -7.5000010e-09      ua       = 2.7607008e-10
+ub       = 1.9582000e-18       uc       = 4.2575840e-11       rdsw     = 6.5700000e+02
+prwb     = -2.7900001e-02      prwg     = 6.8000000e-02       wr       = 1.0000000
+u0       = 5.1113020e-02       a0       = 1.2841400           la0      = -6.3800000e-07
+pa0      = -1.7500000e-12      keta     = -2.0721501e-02      lketa    = -5.0000000e-09
+wketa    = 7.2000000e-09       pketa    = 9.9999980e-15       a1       = 0.00
+a2       = 0.9900000           ags      = 0.1818700           lags     = 1.0000002e-07
+pags     = 5.5000010e-14       b0       = 3.8649000e-07       b1       = 7.2000000e-08
+voff     = -7.5898350e-02      nfactor  = 1.7409346           cit      = -4.7077630e-04
+cdsc     = 2.2212162e-03       cdscb    = 0.00                cdscd    = 0.00
+eta0     = 0.2010600           etab     = -0.1045700          dsub     = 0.5249688
+pclm     = 1.8257079           pdiblc1  = 1.3913199e-02       pdiblc2  = 7.6000000e-03
+pdiblcb  = -0.1250000          drout    = 3.0000000           pscbe1   = 1.0000000e+30
+alpha0   = 2.1000001e-06       alpha1   = 0.00                beta0    = 30.0000000
+kt1      = -0.3713394          kt2      = 0.00                at       = 3.5575000e+04
+ute      = -0.8520300          ua1      = 6.4700000e-09       ub1      = -5.7525000e-18
+uc1      = -8.4126030e-11      kt1l     = -1.0000000e-20      prt      = 0.00
+cj       = 4.35e-04+cjln       mj       = 0.4223898           pb       = 0.9590048
+cjsw     = 3.65e-10+cjswln     mjsw     = 0.1671139           pbsw     = 0.5406927
+cjswg    = 2e-14+cjswgln       mjswg    = 0.33                pbswg    = 0.7
+n        = 1.0                 xti      = 3.0                 cgdo     = 2.00e-10+cgdoln
+cgso     = 2.00e-10+cgsoln     cgbo     = 1.0e-13             capmod   = 2
+dlc      = 1.5184e-07          dwc      = 2.015e-07           vfbcv    = -1
+acde     = 1                   moin     = 15                  noff     = 1
+voffcv   = 0
model lvp bsim3v3
+type  =   p
+tox      = 1.35e-08+toxlp      xj       = 2.0000000e-07
+nch      = 4.3415000e+16       lln      = 1.0000000           lwn      = 1.0000000
+wln      = 1.0000000           wwn      = 1.0000000           lint     = 4.5000000e-11
+ll       = 7.1309870e-14       lw       = -2.5312499e-13      lwl      = -1.8867350e-19
+wint     = 1.9834999e-07       wl       = -2.1250344e-13      ww       = -8.1235000e-14
+wwl      = -1.1351710e-19      mobmod   = 1                   binunit  = 2
+xl       = 0.00e+00+xllp       xw       = 0.00e+00+xwlp     dwg      = -1.2478000e-08
+dwb      = 1.1176000e-08
+ldif     = 0.00                hdif     = 5.00e-07            rsh      = 100
+rdc      = 0
+vth0     = -4.37e-01+vthlp     lvth0    = -5.0000000e-08      wvth0    = -1.3749999e-08
+k1       = 0.4447000           k2       = 2.8000001e-02       k3       = 12.7750040
+dvt0     = 0.6240000           dvt1     = 0.1589000           dvt2     = -3.0400001e-02
+dvt0w    = -2.6686111e-02      dvt1w    = 1.5167305e+05       dvt2w    = -4.9315170
+nlx      = 3.9174720e-07       w0       = -1.3947984e-07      k3b      = -0.5316000
+ngate    = 1.0000000e+23       vfb      = -0.6731328
+vsat     = 1.0256806e+05       ua       = 4.8324240e-10       ub       = 2.2916292e-18
+uc       = -4.1300600e-11      rdsw     = 3.0969299e+03       prwb     = 9.7805430e-03
+prwg     = -5.0262350e-02      wr       = 1.0000000           u0       = 1.6230177e-02
+a0       = 0.3915754           keta     = -6.5810000e-03      lketa    = -2.4800000e-08
+wketa    = 7.0000000e-09       a1       = 0.00                a2       = 0.4000000
+ags      = 1.5620256e-04       b0       = 1.1107368e-06       b1       = 2.3536975e-06
+voff     = -0.4500000          nfactor  = 2.9005730           cit      = -1.5379302e-03
+cdsc     = 0.00                cdscb    = 1.0000000e-20       cdscd    = 0.00
+eta0     = 0.3251730           etab     = 0.00                dsub     = 0.5334910
+pclm     = 4.1747260           pdiblc1  = 2.4428440e-02       pdiblc2  = 1.8528653e-03
+pdiblcb  = 0.1250000           drout    = 3.0000000           pscbe1   = 3.3333330e+08
+alpha0   = 2.4800001e-02       alpha1   = 0.00                beta0    = 91.0000000
+kt1      = -0.5093207          kt2      = -5.6334000e-03      at       = 6.9622000e+03
+ute      = -1.3946000          ua1      = -6.8275000e-10      ub1      = -3.4619000e-19
+uc1      = -7.2356000e-11      kt1l     = -2.1118000e-08      prt      = 1.2000000e+02
+cj       = 8.21e-04+cjlp       mj       = 0.5198076           pb       = 0.9180865
+cjsw     = 4.11e-10+cjswlp     mjsw     = 0.2586436           pbsw     = 0.6054589
+cjswg    = 2.00e-14+cjswglp    mjswg    = 0.33                pbswg    = 0.7
+n        = 1.0                 xti      = 3.0                 cgdo     = 1.00e-10+cgdolp
+cgso     = 1.00e-10+cgsolp     cgbo     = 1.0e-13             capmod   = 2
+voffcv   = 0
endsection spectrebase
section deptt
model depn bsim3v3
+type = n
+lmin     = 0.0e+0              lmax     = 1.0e-3              wmin     = 0.0e+0
+wmax     = 1.0e-3              tnom     = 27.0                version  = 3.2
+tox      = 1.25e-08            xj       = 2.0000000e-07
+nch      = 2.1884999e+16       lln      = 0.3630000           lwn      = 1.0000000
+wln      = 0.6680689           wwn      = 0.4576737           lint     = 2.9300000e-09
+ll       = 9.2800000e-10       lw       = 0.00                lwl      = -3.8900000e-16
+wint     = 3.2745500e-07       wl       = -2.6153500e-12      ww       = -3.4738230e-10
+wwl      = 0.00                mobmod   = 2                   binunit  = 2
+xl       = 0.00                xw       = 0.00                dwg      = -1.7503099e-08
+dwb      = 2.8467641e-08
+ldif     = 0.00                hdif     = 6.00e-07            rsh      = 70
+rdc      = 0
+vth0     = -0.2970000          k1       = 0.2824182           k2       = 5.0140220e-02
+k3       = 4.0372620           dvt0     = 0.6612508           dvt1     = 0.9038930
+dvt2     = 0.1900000           dvt0w    = 4.1514530e-03       dvt1w    = 1.0710410e-30
+dvt2w    = 0.1900000           nlx      = 2.2592779e-30       w0       = -3.0283161e-07
+k3b      = -1.0166310          ngate    = 1.0000000e+23       vfb      = -2.0755069
+vsat     = 8.1000000e+04       ua       = -3.5502000e-11      ub       = 2.3591050e-18
+uc       = -8.3053270e-11      rdsw     = 1.2858920e+03       prwb     = 1.2074960e-02
+prwg     = -4.0917670e-02      wr       = 0.9444284           u0       = 4.7100000e-02
+a0       = -0.1000000          keta     = -6.0882870e-03      a1       = 0.00
+a2       = 0.9900000           ags      = 1.7771060e-02       b0       = 2.7637839e-07
+b1       = -3.7861800e-07
+voff     = -0.1033449          nfactor  = 2.0000000           cit      = -2.1038590e-04
+cdsc     = 0.00                cdscb    = 0.00                cdscd    = 0.00
+eta0     = 0.00                etab     = -2.4141900e-03      dsub     = 0.1000000
+pclm     = 3.0369000           pdiblc1  = 0.1000000           pdiblc2  = 2.1576029e-03
+pdiblcb  = 6.5356970e-02       drout    = 0.5992727           pscbe1   = 3.4641020e+08
+alpha0   = 0.00                alpha1   = 0.00                beta0    = 30.0000000
+kt1      = -0.1100000          kt2      = 2.2000000e-02       at       = 3.3000000e+04
+ute      = -1.5000000          ua1      = 4.3100000e-09       ub1      = 7.6100000e-18
+uc1      = -5.6000000e-11      kt1l     = 0.00                prt      = 0.00
+cj       = 2e-14               mj       = 0.5                 pb       = 1
+cjsw     = 2e-14               mjsw     = 0.33                pbsw     = 1
+cjswg    = 2e-14               mjswg    = 0.33                pbswg    = 0.7
+n        = 1.0                 xti      = 3.0                 cgdo     = 2.5597e-10
+cgso     = 1.8102e-10          cgbo     = 1.0e-13             capmod   = 2
+nqsmod   = 0                   elm      = 5                   xpart    = 0
+cgsl     = -2.4300000e-17      cgdl     = -2.4300000e-17      ckappa   = 0.6000000
+cf       = 0.00                clc      = 7.1776660e-06       cle      = -2.0000000
+dlc      = -2.43e-17           dwc      = -2.43e-17           vfbcv    = -1.1241
+voffcv   = 0
model depp bsim3v3
+type = p
+nch      = 7.5600000e+16       lln      = 2.0000000           lwn      = 1.0000000
+wln      = 2.0000000           wwn      = 0.3500000           lint     = 3.7498580e-09
+ll       = 1.8819650e-20       lw       = 0.00                lwl      = -7.4997160e-26
+wint     = 4.4669360e-07       wl       = -2.3331970e-20      ww       = -2.5349129e-09
+xl       = 0.00                xw       = 0.00                dwg      = -1.9926020e-08
+dwb      = 3.8324790e-08
+ldif     = 0.00                hdif     = 6.00e-07            rsh      = 150
+rdc      = 0
+vth0     = 0.2639070           k1       = 0.5843000           k2       = 5.4800000e-03
+k3       = 27.1811010          dvt0     = 0.2507000           dvt1     = 5.2100000e-02
+dvt2     = 5.0200000e-02       dvt0w    = 2.0800000e-09       dvt1w    = 1.8800000e+05
+dvt2w    = 4.5600000e-02       nlx      = 0.00                w0       = -6.9220100e-09
+k3b      = 0.7294000           ngate    = 1.0000000e+23       vfb      = -0.5289000
+vsat     = 1.2251250e+05       ua       = 6.4456430e-10       ub       = 1.2172310e-18
+uc       = -1.7322660e-10      rdsw     = 1.4992140e+03       prwb     = -0.2000000
+prwg     = 0.1000000           wr       = 1.0218900           u0       = 1.4562040e-02
+a0       = 0.2884466           keta     = -1.3918980e-02      a1       = 0.00
+a2       = 0.4000000           ags      = 2.0000000e-02       b0       = 1.6545310e-07
+b1       = -4.0667760e-07
+voff     = -0.3000000          nfactor  = 2.0000000           cit      = 2.7624480e-03
+cdsc     = 1.4110730e-03       cdscb    = 0.00                cdscd    = 0.00
+eta0     = 8.9858010e-04       etab     = 0.00                dsub     = 0.1000000
+pclm     = 4.6821430           pdiblc1  = 0.1000000           pdiblc2  = 1.8944791e-02
+pdiblcb  = 0.1000000           drout    = 2.9999909           pscbe1   = 3.4641020e+08
+n        = 1.0                 xti      = 3.0                 cgdo     = 3.4925e-10
+cgso     = 6.3816e-09          cgbo     = 1.0e-13             capmod   = 2
+cgsl     = -2.4286130e-17      cgdl     = -2.4286130e-17      ckappa   = 0.6000000
+cf       = 0.00                clc      = 4.9500010e-08       cle      = 0.9110001
+dlc      = -2.428613e-17       dwc      = -2.428613e-17       vfbcv    = -1.6812
+voffcv   = 0
endsection
*************************bjt model*********************************
section bjt
model pnp20 bjt
+type= pnp                      is       = 1.01e-16            bf       = 16.3979
+nf       = 0.9909              vaf      = 261.3346            ikf      = 1.46e-03
+ise      = 4.38e-15            ne       = 1.9797              br       = 0.6531
+nr       = 0.8241              var      = 10.0                ikr      = 1.5
+isc      = 1.00e-17            nc       = 1.5                 rb       = 40.7749
+irb      = 0.0181              rbm      = 9.359               re       = 0.0504
+rc       = 34.1265             xti      = 0.1254              eg       = 1.3133
+cje      = 0.00                vje      = 0.7                 mje      = 0.5
+tf       = 1.00e-10            xtf      = 1.0                 vtf      = 10.0
+itf      = 0.1                 cjc      = 0.00                vjc      = 0.7
+mjc      = 0.5                 xcjc     = 0.5                 fc       = 0.75
+cjs      = 0.00                vjs      = 0.75                mjs      = 0.5
+tr       = 0.00                ptf      = 0.00                kf       = 0.00
+af       = 1.0                 nkf      = 0.5                 cbcp     = 0.00
+cbep     = 0.00                ccsp     = 0.00
+tnom     = 27.0                tlev     = 0                   tlevc    = 0
+xtb      = 1.0
model pnp5 bjt
+type= pnp                      is       = 9.60e-18            bf       = 20.8917
+nf       = 0.994               vaf      = 175.6223            ikf      = 4.91e-04
+ise      = 8.94e-16            ne       = 2.2532              br       = 0.7533
+nr       = 0.796               var      = 10.0                ikr      = 1.5
+isc      = 1.00e-17            nc       = 1.5                 rb       = 127.485
+irb      = 0.5075              rbm      = 9.3901              re       = 0.1002
+rc       = 33.7418             xti      = 10.46               eg       = 1.0678
+xtb      = 1.73
model pnp10 bjt
+type= pnp                      is       = 2.92e-17            bf       = 18.8029
+nf       = 0.9922              vaf      = 228.6814            ikf      = 9.80e-04
+ise      = 2.93e-17            ne       = 1.3754              br       = 0.1981
+nr       = 0.8232              var      = 10.0                ikr      = 1.5
+isc      = 1.00e-17            nc       = 1.5                 rb       = 71.3996
+irb      = 0.0904              rbm      = 9.4964              re       = 0.1344
+rc       = 20.8954             xti      = 0.1                 eg       = 1.2806
+xtb      = 1.0
endsection bjt
*                                resistor models                                                *
* total 6 kinds of resistors are available in this model                                  *
* lib and they're        *
*        1) nwell resistor        *
*        2) n+ resistor        *
*        3) p+ resistor        *
*        4) poly1 resistor        *
*        5) poly2 resistor        *
*        6) hr resistor(either rsh=5k or 1k to can be chosen)                                *
*        usage example: x1 n1 n2 rnwell l=100u w=8u                                        *
* specially,for hr resistor,there are two option(rsh=5k and rsh=1k) to be chosen.        *
*        but couldn't use two hr resistors at the same time in simulation.                *
* the coefficients of resistor are as follows:                                          *
*  resistor        *
*  type   |rsh(ohm/sq) | dl(um) | dw(um) |   vc1   |   vc2   |   tc1   |   tc2          *
*  nwell     849.06      -0.248   1.399   8.48e-03  9.82e-04  5.24e-03  9.56e-06        *
*  nplus     79.10       -0.246   -0.366  1.05e-03  1.34e-03  1.73e-03  -6.17e-07       *
*  pplus     121.71      -0.925   -0.400  -2.35e-03 7.22e-04  9.40e-04  1.40e-06        *
*  poly1     27.53       0.167    0.212   2.32e-04  1.37e-03  7.75e-04  -3.42e-07       *
*  poly2     27.75       0.279    0.419   1.19e-03  2.56e-03  7.08e-04  -2.53e-07       *
*  hr(5k)    4545.68     1.144    0.055   -2.66e-03 -1.81e-03 -4.68e-03 1.58e-05        *
*  hr(1k)    995.792     1.443    0.162   -4.36e-03 -2.73e-03 -3.04e-03 1.15e-05        *
*  r=rsh*(l-dl)/(w-dw)*(1+vc1*|dv|+vc2*dv^2)(1+tc1*(t-tnom)+tc2*(t-tnom)^2)             *
section res
ahdl_include "res_va.va"
******************nwell resistor ********************************************************
subckt rnwell n1 n2
parameters w=1u l=1u
r1 (n1 n2) res_va w=w l=l rsh=849.06
+dl=-0.248u dw=1.399u
+ptc1=5.24e-03 ptc2=9.56e-06
+pvc1=8.48e-03 pvc2=9.82e-04
ends rnwell
***************nplus resistor ***********************************************************
subckt rnplus n1 n2
r1 (n1 n2) res_va w=w l=l rsh=79.10
+dl=-0.246u dw=-0.366u
+ptc1=1.73e-03 ptc2=-6.17e-07
+pvc1=1.05e-03 pvc2=1.34e-03
ends rnplus
***************pplus resistor ***********************************************************
subckt rpplus n1 n2
r1 (n1 n2) res_va w=w l=l rsh=121.71
+dl=-0.925u dw=-0.400u
+ptc1=9.40e-04 ptc2=1.40e-06
+pvc1=-2.35e-03 pvc2=7.22e-04
ends rpplus
***************poly1 resistor ***********************************************************
subckt rpoly1 n1 n2
r1 (n1 n2) res_va w=w l=l rsh=27.53
+dl=0.167u dw=0.212u
+ptc1=7.75e-04 ptc2=-3.42e-07
+pvc1=2.32e-04 pvc2=1.37e-03
ends rpoly1
***************poly2 resistor ***********************************************************
subckt rpoly2 n1 n2
r1 (n1 n2) res_va w=w l=l rsh=27.75
+dl=0.279u dw=0.419u
+ptc1=7.08e-04 ptc2=-2.53e-07
+pvc1=1.19e-03 pvc2=2.56e-03
ends rpoly2
***************hr resistor(rsh=5k) ******************************************************
*subckt rhr5k n1 n2
*parameters w=1u l=1u
*r1 (n1 n2) res_va w=w l=l rsh=4545.68
*+dl=1.144u dw=0.055u
*+ptc1=-4.68e-03 ptc2=1.58e-05
*+pvc1=-2.66e-03 pvc2=-1.81e-03
*ends rhr5k
***************hr resistor(rsh=1k) ******************************************************
subckt rhr1k n1 n2
r1 (n1 n2) res_va w=w l=l rsh=995.792
+dl=1.443u dw=0.162u
+ptc1=-3.042e-03 ptc2=1.150e-05
+pvc1=-4.355e-03 pvc2=-2.733e-03
ends rhr1k
endsection res
endlibrary csmc
 楼主| 发表于 2018-9-3 15:37:19 | 显示全部楼层
回复 4# kekexingren
*simulation                                                             *
*     section deptt                                                     *
是这些吗?
 楼主| 发表于 2018-9-3 15:39:07 | 显示全部楼层
回复 3# rainydate
*simulation                                                             *
*     section deptt                                                     *
library csmc
section tt
parameters
endsection tt
section ff
parameters
endsection ff
section fs
parameters
endsection fs
section sf
parameters
endsection sf
section ss
parameters
endsection ss
section spectrebase
model nmos bsim3v3
+type =n
+rdc      = 0
model pmos bsim3v3
+type = p
+rdc      = 0
model lvn bsim3v3
+type = n
+rdc      = 0
+vfb      = -0.9709756
+voffcv   = 0
model lvp bsim3v3
+type  =   p
+rdc      = 0
+voffcv   = 0
section deptt
model depn bsim3v3
+type = n
+rdc      = 0
+voffcv   = 0
model depp bsim3v3
+type = p
+rdc      = 0
+voffcv   = 0
endsection
section bjt
model pnp20 bjt
+xtb      = 1.0
model pnp5 bjt
+xtb      = 1.73
model pnp10 bjt
+xtb      = 1.0
endsection bjt
*    resistor models      *
* lib and they're         *
* 2) n+ resistor         *
* 3) p+ resistor         *
*  resistor        *
section res
subckt rnwell n1 n2
ends rnwell
subckt rnplus n1 n2
ends rnplus
subckt rpplus n1 n2
ends rpplus
subckt rpoly1 n1 n2
ends rpoly1
subckt rpoly2 n1 n2
ends rpoly2
*subckt rhr5k n1 n2
*ends rhr5k
subckt rhr1k n1 n2
ends rhr1k
endsection res
endlibrary csmc
是在这个文件里吗?
GMT+8, 2025-12-27 13:26 , Processed in 0.021445 second(s), 3 queries , Gzip On, Redis On.
