查看: 12247|回复: 11
请教关于calibre2017和IC617.721集成问题
发表于 2018-8-30 20:33:49 | 显示全部楼层 |阅读模式
以前用calibre2017和IC617.702,没什么大问题。一直报“ *WARNING* (DB-220704): The Pcell super master 'MentorObserverLib/oa_v22_50_001/layout' is not a SKILL super master。The usage of non-SKILL Pcells in Virtuoso is not a supported feature.”似乎也不影响使用。最近把IC617升级到IC617.721,结果cadence启动的时候报错:
//  Calibre Skill Interface * (v2017.1_34.33) *
\o //
\o //                 Copyright Mentor Graphics Corporation 2005
\o //                             All Rights Reserved.
\o //         THIS WORK CONTAINS TRADE SECRET AND PROPRIETARY INFORMATION
\o //            WHICH IS THE PROPERTY OF MENTOR GRAPHICS CORPORATION
\o //              OR ITS LICENSORS AND IS SUBJECT TO LICENSE TERMS.
\o //
\o //
\o END OF SITE CUSTOMIZATION
\p >
\o Loading pe.cxt
\a _treeSetOpcGUI(t)
\r t
\o //  Calibre layout-server initialized successfully at socket 5189, host EDA.
*WARNING* (DB-220706): The Pcell plug-in for super master 'MentorObserverLib/oa_v22_50_001/layout' could not be loaded: Cannot find IPcell 'virtuoso_calibre_client_oa_v22_50_001': Pcell evaluator 'virtuoso_calibre_client_oa_v22_50_001' not found: Shared Library Not Found: Error loading library 'libvirtuoso_calibre_client_oa_v22_50_001.so'. libvirtuoso_calibre_client_oa_v22_50_001.so: cannot open shared object file: No such file or directory...
*WARNING* (DB-220704): The Pcell super master 'MentorObserverLib/oa_v22_50_001/layout' is not a SKILL super master.
\a hiResizeWindow(window(1) list(511:212 1306:405))
\r t
\o //  Calibre v2017.1_34.33    Wed Apr 5 14:22:19 PDT 2017
\o //
\o //        Copyright Mentor Graphics Corporation 1996-2017
\o //
\o //  Mentor Graphics software executing under x86-64 Linux
\o //
\o Calibre server launched successfully
到处找资料也不知道是为啥。哪位大神知道如何解决以上问题?谢谢!
发表于 2018-8-30 21:51:17 | 显示全部楼层
回复 1# hitzhabc
   数据库配置的问题吧
发表于 2018-8-31 15:16:14 | 显示全部楼层
你好,请问能给一个calibre2017的网盘链接吗,谢谢了
 楼主| 发表于 2018-9-1 12:19:44 | 显示全部楼层
回复 4# mismatch24
这个真没有,我也是论坛内搜索分包下载的。不然别的论坛看看吧,也许有
发表于 2018-9-1 15:18:25 | 显示全部楼层
同样的问题,楼主解决了吗?
 楼主| 发表于 2018-9-1 17:45:12 | 显示全部楼层
回复 6# 唐三彩
没。warning不影响使用,看不出有啥问题。只是看着不爽,强迫症...
发表于 2018-9-13 18:38:13 | 显示全部楼层
回复 7# hitzhabc
The problem is solved?
 楼主| 发表于 2018-9-14 16:22:49 | 显示全部楼层
回复 8# Orppis
no.
发表于 2018-11-30 09:49:23 | 显示全部楼层
顶一下,没有其他人碰到?
发表于 2019-2-26 20:48:31 | 显示全部楼层
calibre2017  patch能提供下吗?
谢谢
GMT+8, 2025-12-23 20:29 , Processed in 0.020054 second(s), 3 queries , Gzip On, Redis On.
