查看: 4304|回复: 1
[求助] VMware 虚拟机安装Synopsys问题
发表于 2018-8-19 08:46:38 | 显示全部楼层 |阅读模式
SSS feature没问题,但siteid和hostid均为空,见下。
08/19/2018 08:36:48 (snpslmd) Error at sclLicenseFileGetServerInfo
08/19/2018 08:36:48 (snpslmd) ------------------------------------------------------------------
08/19/2018 08:36:48 (snpslmd) Checking the integrity of the license file....
08/19/2018 08:36:48 (snpslmd) Valid SSS feature found.
08/19/2018 08:36:48 (snpslmd) The feature is needed to enable the other keys in your license file.
08/19/2018 08:36:48 (snpslmd) Licensed to mammoth//ZWT 2006
08/19/2018 08:36:48 (snpslmd) Siteid: <No Site Id>, Server Hostid: , Issued on: N/A
可是,明明已经改了网卡名称(从ens33改为eth0),ifconfig显示:
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.0.102  netmask 255.255.255.0  broadcast 192.168.0.255
        inet6 fe80::e728:80a6:12cb:468b  prefixlen 64  scopeid 0x20<link>
        ether 00:0c:29:2b:5f:97  txqueuelen 1000  (Ethernet)
        RX packets 2454  bytes 944046 (921.9 KiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 802  bytes 167018 (163.1 KiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
lmhostid显示的也是正确的物理地址:
lmhostid - Copyright (c) 1989-2011 Flexera Software, Inc. All Rights Reserved.
The FLEXnet host ID of this machine is "000c292b5f97"
请教大侠,这是什么问题?急救。。。
发表于 2019-11-20 14:17:36 | 显示全部楼层
把license.dat头贴出来看看,可能有些地方没有修改对。
GMT+8, 2025-12-18 18:24 , Processed in 0.013061 second(s), 5 queries , Gzip On, Redis On.
