查看: 6274|回复: 4
[求助] 关于AMS混仿的问题
发表于 2018-8-10 23:31:37 | 显示全部楼层 |阅读模式
ncelab: *E,CUVNCM (./netlist.vams,39|70): No connection module found:Need an input port of continuous discipline electrical, and an output port of discrete discipline logic, at instance adc_0807.I20.
counter_0810 I0 (.con( con ), .out( net4 ), .clk( clk ), .en( net01 ), .nrst( nrst ));
ncelab: *E,CUVNCM (./netlist.vams,41|52): No connection module found:Need an input port of continuous discipline electrical, and an output port of discrete discipline logic, at instance adc_0807.I0.
ncelab: *E,CUVNCM (./netlist.vams,41|66): No connection module found:Need an input port of continuous discipline electrical, and an output port of discrete discipline logic, at instance adc_0807.I0.
发表于 2018-8-11 09:39:57 | 显示全部楼层
在IUS的目錄下面有個connect_lib的庫,添加到lib manager里,然後在ADE里設置一下connect rule就好了。
回复 支持 3 反对 0
发表于 2018-8-16 17:10:20 | 显示全部楼层
看起来是库没有加全导致的
发表于 2020-11-16 15:12:01 | 显示全部楼层
是的,二楼正解
发表于 2024-9-5 14:16:09 | 显示全部楼层
远上寒杉 发表于 2018-8-11 09:39
在IUS的目錄下面有個connect_lib的庫,添加到lib manager里,然後在ADE里設置一下connect rule就好了。 ...
mark 一下
GMT+8, 2025-12-18 08:40 , Processed in 0.017282 second(s), 4 queries , Gzip On, Redis On.
