楼主: lins0513
关于 boost, buck, boost/buck的文档
发表于 2010-12-14 10:43:14 | 显示全部楼层
's just the bode plot of the plant stage, seeing from the negative gain of the low frequency. Actually, you need to add the control circuit which will give enough gain at low frequency (for example, 80db or greater) and model the pwm block ( if you use such method, that means you need to model the switch and diode). After including the control circuit, the whole loop gain will be changed into positive, and you can measure the loop stablity. For system design, you need to get the model of the control IC(normally, can model it as OTA, and adding the compensation component).
发表于 2011-4-21 15:19:03 | 显示全部楼层
好东西,下了,
发表于 2011-6-2 12:02:00 | 显示全部楼层
什么文档,看啊看
发表于 2012-3-12 23:56:30 | 显示全部楼层
收藏了先, 谢谢
发表于 2013-2-16 10:01:11 | 显示全部楼层
非常感谢。。正需要看看boost-buk
发表于 2016-7-13 09:54:45 | 显示全部楼层
蟹蟹露珠→_→。。。
GMT+8, 2025-12-25 17:17 , Processed in 0.014544 second(s), 3 queries , Gzip On, Redis On.
