查看: 1306|回复: 0
[招聘] NO.73-Principal serdes design engineer(Nanjing)
发表于 2018-7-4 17:23:53 | 显示全部楼层 |阅读模式
JOB DESCRIPTION:
- Design, simulation and verification of high speed serdes at data rates of 10Gb/s and higher.
- High speed blocks AMS modeling and support IP verification in digital top
- Define specifications of IC blocks and create design documentation.
- Design of IC blocks and supervise layout floor plan.
- Silicon test, characterization and lab debugging.
- Knowledge sharing within design team
QUALIFICATION:
  • MSEE or above with minimum 5+ years of working/research experience in high-speed CMOS SerDes design (CTLEs, PLLs, DFEs, etc.)
  • Experience in high speed designs (e.g. USB3.0/3.1, PCIe, HDMI, SATA, DisplayPort, SerDes) preferred.
  • Strong lab experience on silicon debugging, good understanding on lab instruments (e.g oscilloscope, Error Bert)
  • Good understanding of high-speed layout considerations, such as parasitic, crosstalk isolation, supply and bias distribution, etc.
  • Proficient with Cadence design environment and mixed-signal simulation (ADE, Layout, AMS), mixed-signal simulation (AMS), EM simulation (such as EMX)
  • Working knowledge of theoretical and practical aspects of electro-magnetic structures including transmission lines, spiral inductors, resonant circuits, etc. (HFSS experience is a plus)
  • Able to assume responsibility for a variety of technical tasks and to work independently
  • Able to be hands-on at all levels of design, with the ability to verify, test, and characterize own designs
  • Good communication skill and good command of written English are highly desired.
KT Human Resources Consulting Company (Shanghai) was established in 2001 in response to a need for a recruitment consultancy to be an active, contributing member of the semiconductor community, as opposed to simply a supplier to it.We provide professional search and talent acquisition in the Integrated Circuit、Electronic、Telecommunications industry of international corporations in Greater China. Our client list contains numerous international companies, many of them are long-term customers.
If you interested in the job, pls sent your cv to: hr@kthr.com, thanks!
“凯轶—KT咨询”微信也可查询职位啦!打开手机微信,搜号码“KTHR_COM”或查找微信公众帐号“凯轶—KT咨询”即可添加,欢迎大家关注!
或者直接扫我哦!
GMT+8, 2025-11-8 20:00 , Processed in 0.014663 second(s), 4 queries , Gzip On, Redis On.
