楼主: nano_dv
[资料] PT-2015-lab和sta
发表于 2019-5-19 20:23:50 | 显示全部楼层
Thank you for sharing
发表于 2019-8-27 09:09:00 | 显示全部楼层
谢谢分享,花了好多信元,值
发表于 2020-2-24 14:44:31 | 显示全部楼层
thanks
发表于 2020-2-27 11:11:42 | 显示全部楼层
version 2002, thanks~
发表于 2020-11-8 13:47:02 | 显示全部楼层
请问有userguide吗就这个lab
发表于 2020-12-11 09:11:17 | 显示全部楼层
谢谢分享,就是少个lab guide
发表于 2021-1-30 15:14:53 | 显示全部楼层
楼主,网表设计跟寄生参数匹配不上.
还请帮忙分享匹配得上的2个文件: orca_routed.v.gz和 ORCA.SPEF.gz
多谢了
pt_shell> read_verilog orca_routed.v.gz
1
pt_shell>
pt_shell> link_design ORCA
Loading db file '/mylab/PT_2015.06/ref/libs/sc_max.db'
Loading db file '/mylab/PT_2015.06/ref/libs/io_max.db'
Loading db file '/mylab/PT_2015.06/ref/libs/special.db'
Loading db file '/mylab/PT_2015.06/ref/libs/mem_max.db'
Loading verilog file '/mylab/PT_2015.06/ref/design_data/orca_routed.v.gz'
Linking design ORCA...
Information: Removing 24 unneeded designs..... (LNK-034)
Information: 439 (81.75%) library cells are unused in library cb13fs120_tsmc_max..... (LNK-045)
Information: 82 (95.35%) library cells are unused in library cb13io320_tsmc_max..... (LNK-045)
Information: total 521 library cells are unused (LNK-046)
Design 'ORCA' was successfully linked.
Information: There are 20403 leaf cells, ports, hiers and 24967 nets in the design (LNK-047)
1
pt_shell>
pt_shell> read_parasitics ORCA.SPEF.gz
Information: Derived library resistance unit is 1.000000 Kohm (Time unit is 1 ns, and Capacitance unit is 1.000000 pF). (DES-028)
Error: Cannot find net '*Logic1*' in design 'ORCA' (PARA-124)
Error: Cannot find port/pin 'I_ORCA_TOP/I_SDRAM_WRITE_FIFO/Logic1/output' in design 'ORCA' (PARA-124)
Error: Cannot find net '*Logic0*' in design 'ORCA' (PARA-124)
Error: Cannot find port/pin 'I_ORCA_TOP/I_SDRAM_WRITE_FIFO/Logic0/output' in design 'ORCA' (PARA-124)
Error: Cannot find port/pin 'I_ORCA_TOP/I_RISC_CORE/I_REG_FILE/Logic1/output' in design 'ORCA' (PARA-124)
Error: Cannot find port/pin 'I_ORCA_TOP/I_RISC_CORE/I_REG_FILE/Logic0/output' in design 'ORCA' (PARA-124)
Error: Cannot find port/pin 'I_ORCA_TOP/I_SDRAM_READ_FIFO/Logic0/output' in design 'ORCA' (PARA-124)
Error: Cannot find port/pin 'I_ORCA_TOP/I_SDRAM_READ_FIFO/Logic1/output' in design 'ORCA' (PARA-124)
Error: Cannot find port/pin 'I_ORCA_TOP/I_RESET_BLOCK/Logic1/output' in design 'ORCA' (PARA-124)
Error: Cannot find port/pin 'I_ORCA_TOP/I_PCI_WRITE_FIFO/Logic1/output' in design 'ORCA' (PARA-124)
Error: Cannot find port/pin 'I_ORCA_TOP/I_PCI_WRITE_FIFO/Logic0/output' in design 'ORCA' (PARA-124)
Error: Cannot find port/pin 'I_ORCA_TOP/I_SDRAM_IF/Logic0/output' in design 'ORCA' (PARA-124)
Error: Cannot find port/pin 'I_ORCA_TOP/I_SDRAM_IF/Logic1/output' in design 'ORCA' (PARA-124)
Error: Cannot find port/pin 'I_ORCA_TOP/I_CONTEXT_MEM/Logic0/output' in design 'ORCA' (PARA-124)
Error: Cannot find port/pin 'I_ORCA_TOP/I_CONTEXT_MEM/Logic1/output' in design 'ORCA' (PARA-124)
Error: Cannot find port/pin 'I_ORCA_TOP/I_PCI_READ_FIFO/Logic1/output' in design 'ORCA' (PARA-124)
Error: Cannot find port/pin 'I_ORCA_TOP/I_PCI_READ_FIFO/Logic0/output' in design 'ORCA' (PARA-124)
Report : read_parasitics /mylab/PT_2015.06/ref/design_data/ORCA.SPEF.gz
Design : ORCA
Date   : Fri Jan 29 23:10:33 2021
        45 error(s)
        Format is SPEF
        Annotated nets                   :        22678
        Annotated capacitances           :       101979
        Annotated resistances            :        79301
        Reduced coupling capacitances    :            0
        Annotated PI models              :            0
        Annotated Elmore delays          :            0
1
发表于 2021-1-30 15:59:45 | 显示全部楼层
请楼主抽空瞧瞧.
2个design_data目录内文件不匹配....
如何改正??pt_shell> lappend link_path sc_max.db io_max.db special.db mem_max.db
* sc_max.db io_max.db special.db mem_max.db
1
Loading db file '/mylab/PT_1_2011.12/ref/libs/sc_max.db'
Loading db file '/mylab/PT_1_2011.12/ref/libs/io_max.db'
Loading db file '/mylab/PT_1_2011.12/ref/libs/special.db'
Loading db file '/mylab/PT_1_2011.12/ref/libs/mem_max.db'
Loading verilog file '/mylab/PT_1_2011.12/ref/design_data/orca_routed.v.gz'
1
Report : read_parasitics /mylab/PT_1_2011.12/ref/design_data/ORCA.SPEF.gz
Design : ORCA
Date   : Fri Jan 29 23:46:00 2021
        45 error(s)
        Format is SPEF
1
发表于 2021-2-26 13:29:11 | 显示全部楼层
多谢分享
发表于 2021-3-16 21:29:52 | 显示全部楼层
Thanks for sharing
GMT+8, 2025-12-18 00:50 , Processed in 0.020218 second(s), 4 queries , Gzip On, Redis On.
