Eric R. Fossum is best known for the invention of the CMOS image sensor “camera-on-a-chip” used in billions of cameras, from smart phones to web cameras to pill cameras and many other applications. He is a solid-state image sensor device physicist and engineer, and his career has included academic and government research, and entrepreneurial leadership. He is currently a Professor with the Thayer School of Engineering at Dartmouth in Hanover.----------------------------------------------------------------------------------------------------------------------------------------
以下是publication列表,有少量很老的几篇没下载到,但大部分比较新的都收集到了。文件数目比较多,导致压缩包比较大,在这里分成15个包裹了。
E.R. Fossum and R.C. Barker, Charge Packet Initiated Switching of Metal/Tunnel Oxide/Semiconductor Junctions, IEEE Electron Device Lett., vol. EDL-5, pp. 112-114, 1984.
E.R. Fossum and R.C. Barker, Measurement of Hole Leakage and Impact Ionization Currents in Metal/Tunnel Oxide/Semiconductor Junctions, IEEE Trans. Electron Devices, vol. ED-3l, no. 9, pp. 1168-1174, 1984.
E.R. Fossum and R.C. Barker, A Linear and Compact Charge Packet Differencer/ Replicator, IEEE Trans. Electron Devices, vol. ED-31, no. 12, pp. 1784-1789, 1984.
P.R. Prucnal, E.R. Fossum, and R.M. Osgood, Integrated Fiber Optic Coupler for Very Large-Scale Integration Interconnects, Optics Lett., vol. 11, no. 2, pp. 109-111, 1986.
S.S. Todorov, S.L. Shillinger, and E.R. Fossum, Low Energy Ion Beam Oxidation of Silicon, IEEE Electron Dev. Lett., vol. EDL-7, pp. 468-470, 1986.
S.S. Todorov, C.F. Yu, and E.R. Fossum, Direct Formation of Dielectric Thin Films on Silicon by Low Energy Ion Beam Bombardment, Vacuum, 36 (11/12), pp. 929-932, 1986.
R.W. Ade, E.E. Harstead, A.H. Amirfazli, T. Cacouris, E.R. Fossum, P.R. Prucnal, and R.M. Osgood, Silicon Photodetector Structure for Direct Coupling of Optical Fibers to Integrated Circuits, IEEE Trans. Electron Devices, vol. ED-34, pp. 1283-1289, 1987.
C.F. Yu, S.S. Todorov, and E.R. Fossum, Characterization of Ultra-Thin SiO2 Films Formed by Direct Low Energy Ion Beam Oxidation, J. Vac. Sci. and Technol. A5(4), pp. 1569-1571, 1987.
E.R. Fossum, Charge-Coupled Computing for Focal Plane Image Preprocessing, Opt. Eng., 26 (9), pp. 916-922, 1987.
R.W. Ade and E.R. Fossum, Limitations of Orientation Dependent Microstructure Etching in Silicon, J. Electrochem. Soc., vol. 134 (12), pp. 3192-3194, 1987.
D.V. Rossi, E.R. Fossum, G.D. Pettit, P.D. Kirchner, and J.M. Woodall, Reduced Reverse Bias Current in Al-GaAs and In0.75 Ga0.25 As-GaAs Junctions Containing an Interfacial Arsenic Layer, J. Vac. Sci. and Technol. vol. B5 (4), pp. 982-984, 1987.
J.I. Song and E.R. Fossum, Inhibition of Charge Packet Broadening in GaAs Charge-Coupled Devices, Appl. Phys. Lett., vol. 51, 19), pp. 1539-1541, 1987.
A.Warren, J.M. Woodall, E.R. Fossum, G.D. Pettit, P.D. Kirchner and D.T. McInturff, Masked, anisotropic thermal etching and regrowth for in situ patterning of compound semiconductors, Appl. Phys. Lett., vol. 51 (22), pp. 1818-1820, 1987.
S.S. Todorov and E.R. Fossum, Oxidation of Silicon by a Low Energy Ion Beam: Model and Experiment, Appl. Phys. Lett., vol. 52 (1), pp. 48-50, 1988.
S.S. Todorov and E.R. Fossum, Growth Mechanism of Thin Oxide Films Under Low Energy Oxygen Ion Bombardment, J. Vac. Sci. and Technol. B. B, vol. 6 (1), pp. 466-469, 1988.
S.S. Todorov and E.R. Fossum, Sputtering of Silicon Dioxide Near Threshold, Appl. Phys. Lett., vol. 52 (5), pp. 365-367, 1988.
R.W. Ade, E.R. Fossum, M.A. Tischler, Fabrication of Thin Epitaxial GaAs/AlGaAs Diaphragms by Selective Dry Etching, J. Vac. Sci. and Technol., vol. B6 (5), pp. 1592-1594, 1988.
E.R. Fossum, Charge-Domain Analog Signal Processing for Detector Arrays, Nuclear Instr. and Methods, vol. A275, pp. 530-535, 1989.
E.R. Fossum, Novel Trench-Defined MISIM CCD Structure for X-Ray Imaging and Other Applications, IEEE Electron Device Lett., vol. 10 (5), pp. 177-179, 1989.
E.R. Fossum, Architectures for Focal-Plane Image Processing, Opt. Eng., vol. 28 (8), 865-871, 1989.
J.I. Song and E.R. Fossum, Characterization of Evaporated Cr-SiO Cermet Films for Resistive-Gate CCD Applications, IEEE Trans. Electron Devices, vol. 36 (9), 1575-1579, 1989.
R.E. Colbeth, J.-I. Song, D.V. Rossi and E.R. Fossum, A Recessed Gap, Capacitive Gate GaAs CCD, IEEE Electron Device Letters, vol. 10 (12), 525-527, 1989.
R.W. Ade, E.R. Fossum and M.A. Tischler, Performance of Vertically Coupled Backside Fiber-Optic Interconnects to GaAs, (abstract) IEEE Trans. Electron Devices, vol. 36 (11), 2629, 1989.
R.E. Colbeth and E.R. Fossum, A 1 GHz Charge Packet Replicator/Subtractor Circuit for GaAs CCD Signal Processing, IEEE J. Solid-State Circuits, vol. 25(4), pp. 1016-1019, 1990.
D.V. Rossi, E.R. Fossum, P.D. Kirchner and J.M. Woodall, Transport Properties and Applications of Unstrained InGaAs/AlGaAs Heterojunctions, J. Vac. Sci. Technol. B, vol. 8(4), pp. 779-782, 1990.
B. Pain and E.R. Fossum, Analog Dynamic Random-Access Memory (ADRAM) Unit Cell Implemented in Charge Domain, IEEE Trans. Electron Devices, vol. 38(1) pp. 178-179, 1991.
E.R. Fossum, Wire Transfer of Charge Packets Using a CCD-BBD Structure for Charge-Domain Signal Processing, IEEE Trans. Electron Devices, vol. ED-38(2) pp.291-298, 1991.
E.R. Fossum, S.E. Kemeny, R.A. Bredthauer and M.A. LaShell, Digitally Programmable gain control circuit for charge-domain signal processing, IEEE J. Solid-State Circuits, vol. 26(4) pp. 683-686, 1991.
J.-I. Song, D.V. Rossi, S-H Xin, W.I. Wang and E.R. Fossum, A Resistive-Gate AlGaAs/GaAs 2DEG CCD with High Transfer Efficiency at 1 GHz, IEEE Trans. Electron Devices, vol. ED-38, pp. 930-932, 1991.
E.R. Fossum, J.-I. Song, and D.V. Rossi, Two-Dimensional Electron Gas Charge-Coupled Devices (2DEG-CCDs), IEEE Trans. Electron Devices, vol. ED-38(5), pp. 1182-1192, 1991.
D.V. Rossi, J.-I. Song, E.R. Fossum, P.D. Kirchner, G.D. Pettit, and J.M. Woodall, A Resistive-Gate In0.53 Ga0.47As/InP Heterostructure CCD, IEEE Electron Device Lett., vol. EDL-12(12) pp. 688-690, 1991.
S.E. Kemeny, H. Torbey, H. Meadows, R. Bredthauer, M. LaShell, and E.R. Fossum, CCD Focal-Plane Image Reorganization Processors for Lossless Image Compression, IEEE J. Solid-State Circuits, vol. 27(3), pp. 398-405, 1992.
T.J. Cunningham, E.R. Fossum, and S.M. Baier, An analysis of the temperature dependence of the gate current in complementary heterojunction field-effect transistors, IEEE Electron Device Lett., vol. 13(12) pp. 645-647, 1992.
W.R. Cook, A.C. Cummings, R.A. Mewaldt, J.J. Rosenberg, T.J. Cunningham, M. Mazed, M.J. Holtzman, and E.R. Fossum, Development of an interdigitated pixel PIN detector for energetic particle spectroscopy in space, Remote Sensing Reviews, vol. 8, pp. 245-253, 1993.
S.Mendis, S.E. Kemeny and E.R. Fossum, CMOS active pixel image sensor, IEEE Trans. Electron Devices, vol. 41(3), pp. 452-453, 1994.
T.J. Cunningham, R.C. Gee, E.R. Fossum and S.M. Baier, Deep cryogenic noise and electrical characterization of the complementary heterojunction field-effect transistor (CHFET), IEEE Trans. Electron Devices, vol. 41(6), pp. 888-894, 1994.
B. Pain and E.R. Fossum, A current memory cell with switch feedthrough reduction by error feedback, IEEE J. Solid-State Circuits, vol. 29(10), pp. 1288-1290, 1994.
A.R. Johnston, D. Liu, S. Forouhar, G. Lutes, J. Maserjian and E.R. Fossum, Optical links for cryogenic focal-plane array readout, Optical Engineering, vol. 33(6), pp. 2013-2019, 1994.
T.J. Cunningham and E.R. Fossum, GaAs JFETS intended for deep cryogenic VLWIR readout electronics, Journal de Physique IV, vol. 4(C6) pp. 147-152, 1994.
J. Nakamura, S.E. Kemeny and E.R. Fossum, A CMOS active pixel image sensor with simple floating gate pixels, IEEE Trans. Electron Devices, vol. ED-42(9) pp. 1693-1694, 1995.
B.P. Beecken and E.R. Fossum, Determination of the conversion gain and the accuracy of its measurement for detector elements and arrays, Applied Optics, Vol. 35, No. 19, p. 3471- 3477, 1996
R.H Nixon, S.E. Kemeny, B. Pain, C.O. Staller and E.R. Fossum, 256x256 CMOS active pixel sensor camera-on-a-chip, IEEE J. Solid-State Circuits, vol. 31(12) pp. 2046-2050, 1996.
S.K. Mendis, S.E. Kemeny, R.C. Gee, B. Pain, Q. Kim, and E.R. Fossum, CMOS active pixel image sensors for highly integrated imaging systems, IEEE J. Solid-State Circuits, vol. 32(2) pp. 187-197, 1997.
O. Yadid-Pecht, B. Pain, C. Staller, C. Clark, and E.R. Fossum, CMOS active pixel sensor star tracker with regional electronic shutter, IEEE J. Solid-State Circuits, vol. 32(2) pp. 285-288, 1997.
G.A. Soli, H.B. Garrett, E.R. Fossum, CMOS charged particle spectrometers, IEEE Trans. Nuclear Science, vol. 43(3) pt 2. Page: 1516-1520, 1996.
O. Yadid-Pecht, C. Staller, and E.R. Fossum, Wide intrascene dynamic range CMOS APS using dual sampling, IEEE Trans. Electron Devices, vol. 44(10) pp. 1721-1723, 1997.
J. Nakamura, B. Pain, T. Nomoto, T. Nakamura, and E.R. Fossum, On-focal plane signal processing for current-mode active pixel sensors, IEEE Trans. Electron Devices, vol. 44(10) pp. 1747-1758, 1997.
Z. Zhou, B. Pain, and E.R. Fossum, Frame-transfer CMOS active pixel sensor with pixel binning for variable resolution readout, IEEE Trans. Electron Devices, vol. 44(10) pp. 1764-1768, 1997.
Z. Zhou B. Pain and E.R. Fossum, CMOS active pixel sensor with on-chip successive approximation analog-to-digital converters, IEEE Trans. Electron Devices, vol. 44(10) pp. 1759-1763, 1997.
E.R. Fossum, CMOS image sensors - electronic camera on a chip, IEEE Trans. Electron Devices, Special Issue on Solid-State Image Sensors, October 1997 vol. 44(10) pp. 1689-1698, 1997.
E.R. Fossum, CMOS active pixel image sensors, Nuclear Instruments and Methods in Physics Research A, vol. 395(3) pp. 291-297, 1997.
E.R.Fossum, Guest Editor-in-Chief, IEEE Transactions on Electron Devices Special Issue on Solid-State Image Sensors, vol. 44 (10) October 1997 . See also Tributes to the Late Dr. Walter Kosonocky
S.E. Kemeny, R. Panicacci, B.Pain, L. Matthies, and E.R. Fossum, Multiresolution image sensor, IEEE Trans. Circuits and Systems for Video Technology, vol. 7(4), pp. 575-583, 1997.
J. Fattaruso, E.R. Fossum, and T.H. Lee, Guest Editors, IEEE J. Solid State Circuits Special Issue on the 1997 ISSCC: Analog, Sensor and Communication Circuits, vol. 32(12) December 1997.
E.R. Fossum, Digital Camera System-On-A-Chip, IEEE Micro, vol. 18(3), pp 8-15, May/June, 1998.
S. Campbell and E.R. Fossum, Detector arrays for digital holographic storage, Holographic Data Storage, pp.271-279, Hans Coufal, Demetri Psaltis, Glenn Sincerbox, editors, Springer-Verlag Optical Science Series, 2000.
Eid, E.-S., Spagnuolo, R., Chan, T. Y., Fossum, E. R., Tsai, R. H., Deily, J., Byers Jr., W. B.; Peden, J. C., Design and characterization of ionizing radiation-tolerant CMOS APS image sensors up to 30 Mrd (Si) total dose, IEEE Transactions on Nuclear Science (ISSN 0018-9499), vol. 48, no. 6, Dec. 191, p. 1796-1806. December 2001
K-B Cho, A. Krymski, E.R. Fossum, A 1.5V 550 uW 176x144 autonomous CMOS active pixel image sensor, IEEE Transactions on Electron Devices, vol. 50(1), pp. 96-105 (2003.
A. Krymski, N. Bock, N. Tu, D. Van Blerkom, and E. R. Fossum, A high-speed, 240 frame/second, 4.1 megapixel image sensor, IEEE Transactions on Electron Devices, vol. 50(1), pp. 130-135 (2003.
I. Takayanagi, J. Nakamura, Eric R. Fossum, K. Nagashima, T. Kunihiro and H. Yurimoto, Dark current reduction in stacked-type CMOS-APS for charged particle imaging, IEEE Transactions on Electron Devices, vol. 50(1), pp. 70-76 (2003.
E.R. Fossum, Guest Editor-in-Chief, IEEE Transactions on Electron Devices Special Issue on Solid-State Image Sensors, vol. 50(1) January 2003.
I. Takayanagi, M. Shirakawa, K. Mitani, M. Sugawara, S. Iversen, J. Moholt, J. Nakamura, and E.R. Fossum, A 1.25-inch 60-frame/s 8.3M-pixel digital output CMOS image sensor, IEEE J. Solid State Circuits, vol. 40(11) pp. 2305-2314 November 2005.
E.R. Fossum, Guest Editor-in-Chief, IEEE Transactions on Electron Devices Special Issue on Solid-State Image Sensors, vol. 56(11) November 2009.
E.R. Fossum, Guest Editorial, IEEE Transactions on Electron Devices Special Issue on Solid-State Image Sensors, vol. 56(11) pp. 2376-2379 November 2009.
E.R. Fossum, Modeling the performance of single-bit and multi-bit quanta image sensors, IEEE J. Electron Devices Society, vol.1(9) pp. 166-174 September 2013.
E.R. Fossum, Camera-on-a-Chip: Technology Transfer From Saturn to Your Cell Phone, Technology and Innovation, Vol. 15, pp. 197–209, December 2013.
T-Y. Lee, Y-J. Lee, D-K. Min, S-H. Lee, W-H. Kim, J-K. Jung, I. Ovsiannikov, Y-G. Jin, YD. Park, and E.R. Fossum, A time-of-flight 3-D image sensor with concentric-photogates demodulation pixels, IEEE Trans. Electron Devices, vol. 61, no. 3, pp. 870-877 March 2014.
S. Masoodian, K. Odame, and E.R. Fossum, Low-power readout circuit for quanta image sensors, Electronics Letters, Vol. 50 No. 8 pp. 589–591 April 2014.
E.R. Fossum and D. Hondongwa, A review of the pinned photodiode for CCD and CMOS image sensors, IEEE J. Electron Devices Society, vol. 2(3) pp. 33-43 May 2014.
L. Anzagira and E.R. Fossum, Color filter array patterns for small-pixel image sensors with substantial cross talk, J. Opt. Soc. Am. A, Vol. 32(1), pp. 28-34 January 2015.
J. Ma and E.R. Fossum, A Pump-Gate Jot Device with High Conversion Gain for Quanta Image Sensors, IEEE J. Electron Devices Society, vol. 3(2), pp. 73-77, March 2015.
J. Ma and E.R. Fossum, Quanta image sensor jot with sub 0.3e- r.m.s. read noise and photon counting capability, IEEE Electron Device Letters, vol. 36(9), pp. 926-928, September 2015.
J. Ma, D. Starkey, A. Rao, K. Odame, and E.R. Fossum, Characterization of quanta image sensor pump-gate jots with deep sub-electron read noise, IEEE J. Electron Devices Society, vol. 3(6), pp. 472-480, November 2015.
S. Masoodian, A. Rao, J. Ma, K. Odame and E.R. Fossum, A 2.5pJ/b binary image sensor as a pathfinder for quanta image sensors, IEEE Trans. Electron Devices, vol. 63(1), pp. 100-105, January 2016.
J. Ma, L. Anzagira, and E.R. Fossum, A 1μm-pitch quanta image sensor jot device with shared readout, IEEE J. Electron Devices Society, vol. 4(2), pp. 83-89, March 2016.
D.A. Starkey and E.R. Fossum, Determining conversion gain and read noise using a photon-counting histogram method for deep sub-electron read noise image sensors, IEEE J. Electron Devices Society, vol. 4, no. 3, pp. 129-135, May 2016. https://doi.org/10.1109/JEDS.2016.2536719
E.R. Fossum, Photon counting error rates in single-bit and multi-bit quanta image sensors, IEEE J. Electron Devices Society, vol. 4, no. 3, pp. 136-143, May 2016. https://doi.org/10.1109/JEDS.2016.2536722
L. Anzagira and E.R. Fossum, Application of the quanta image sensor concept to linear polarization imaging – a theoretical study, J. Opt. Soc. Am. A, Vol. 33, Issue 6, pp. 1147-1154, June 2016. https://doi.org/10.1364/JOSAA.33.001147
E. Amri, Y. Felk, D. Stucki, J. Ma and E.R. Fossum, Quantum random number generation using a quanta image sensor, MDPI Sensors, vol. 16, no. 7, 1002, June 2016. (Special Issue on Photon-Counting Image Sensors) https://doi.org/10.3390/s16071002
E.R. Fossum, J. Ma, S. Masoodian, L. Anzagira, and R. Zizza, The quanta image sensor: every photon counts, MDPI Sensors, vol. 16, no. 8, 1260; August 2016. (Special Issue on Photon-Counting Image Sensors) https://doi.org/10.3390/s16081260
E.R. Fossum, N. Teranishi, A. Theuwissen, D. Stoppa and E. Charbon, (Eds.), Photon-Counting Image Sensors, MDPI ISBN 978-3-03842-375-1 (PDF) ISBN 978-3-03842-374-4 (Pbk), 366 pages, published 9-May-2017. retrieved 13-Aug-2017 from http://www.mdpi.com/books/pdfview/book/288
J. Ma and E.R. Fossum, Analytical modeling and TCAD simulation of a quanta image sensor jot device with a JFET source-follower for deep sub-electron read noise, IEEE J. Electron Devices Society, vol. 5, no. 1, pp. 69-78, January 2017. https://doi.org/10.1109/JEDS.2016.2618721
E.R. Fossum, C.E. Fraser, and J.J. Helble, The PhD Innovation Program at the Thayer School of Engineering at Dartmouth, Technology and Innovation, Vol. 19, pp. 381-388, 2017 https://doi.org/10.21300/19.1.2017.381
S. Chen, J. Ma, D.B. Hondongwa, and E.R. Fossum, High Conversion-gain pinned-photodiode pump-gate pixels in 180nm CMOS process, IEEE J. Electron Devices Society, vol. 5, no. 6, pp. 509-517, November 2017. https://doi.org/10.1109/JEDS.2017.2748883
Y. Zhang, Y. Wu, X. Wang, E.R. Fossum, R. Kumar, J. Liu, G. Salamo, and S-Q. Yu, Non-avalanche single photon detection without carrier transit-time delay through quantum capacitive coupling, OSA Optics Express, vol. 25, no. 22, pp. 26508-26518, October 2017 https://doi.org/10.1364/OE.25.026508
J. Ma, S. Masoodian, D. Starkey, E.R. Fossum, Photon-number-resolving megapixel image sensor at room temperature without avalanche gain, OSA Optica, vol. 4, no. 12, pp.1474-1481, December 2017. https://doi.org/10.1364/OPTICA.4.001474
Y. Zhang, Y. Wu, X. Wang, L. Ying, R. Kumar, Z. Yu, E.R. Fossum, J. Liu, G. Salamo, and S.-Q. Yu, Detecting single photons using capacitive coupling of single quantum dots, ACS Photonics, 9 March 2018, https://doi.org/10.1021/acsphotonics.7b01515
D.B. Hondongwa and E.R. Fossum, Drift field implementation in large pinned photodiodes for improved charge transfer speed, IEEE J. Electron Devices Society, vol. 6, pp. 413-419, 20 March 2018. https://doi.org/10.1109/JEDS.2018.2792311
Other Peer Reviewed Publications
D.V. Rossi, E.R. Fossum, G.D. Pettit, P.D. Kirchner, and J.M. Woodall, Reduced Leakage Current in Al-GaAs and In0.75 Ga0.25 As-GaAs Junctions Containing an Interfacial Arsenic Layer, in Proceeding of the 1987 Conference on the Physics and Chemistry of Semiconductor Interfaces, Salt Lake City, Utah, January 1987.
R.E. Colbeth, J.I. Song, D.V. Rossi, and E.R. Fossum, A 1 GHz GaAs CCD with Capacitive Gates and High Transfer Efficiency, Proc. 1989 Int'l Symp. on VLSI Tech., Sys., and Applications, Taipei, pp. 45-49, 1989.
E.R. Fossum, New CCDs and Circuits for Analog VLSI Focal Plane Image Processing, Proc. 1989 Int'l. Symp. on VLSI Tech., Sys., and Applications, pp. 178-182 Taipei, 1989.
J.-I. Song and E.R. Fossum, A Resistive-Gate Two-Phase 2DEG-CCD for III-V IR Detectors, in Technical Digest of the 1990 IEEE International Electron Devices Meeting (IEDM), pp. 267-270, San Francisco, CA, Dec. 1990.
S.E. Kemeny, H. Torbey, H. Meadows, E.R. Fossum, R. Bredthauer, and M. LaShell, CCD Image Sensor with Differential, Pyramidal Output for Lossless Image Compression, Proc. 1991 IEEE Custom Integrated Circuits Conf., San Diego, CA, May 1991.
S.E. Kemeny, T.J. Shaw, R.H. Nixon, and E.R. Fossum, Parallel processor array for high speed path planning, in Proc. 1992 IEEE Custom Integrated Circuits Conf., pp. P.6.5/1-5, Boston, MA, May 1992.
D.V. Rossi, A. Cheng, H. Wieder, and E.R. Fossum, A Resistive-Gate InAlAs/InGaAs/InP 2DEG CCD, in Technical Digest of the 1992 IEEE International Electron Devices Meeting (IEDM), pp. 117-120, San Francisco, CA December 1992.
S. Mendis, S. Kemeny and E.R. Fossum, A 128x128 CMOS active pixel image sensor for highly integrated imaging systems, in Technical Digest of the 1993 IEEE International Electron Devices Meeting (IEDM), pp. 583-586, Washington D.C. December 5-8 1993.
A. Dickinson, B. Ackland, E-S. Eid, D. Inglis and E.R. Fossum, A 256x256 CMOS active pixel image sensor with motion detection, 1995 IEEE International Solid State Circuits Conference, Digest of Technical Papers, pp. 226-227, San Francisco CA, February 1995.
E.R. Fossum, Low power camera-on-a-chip using CMOS active pixel sensor technology, (invited) Proc. 1995 IEEE Symposium on Low Power Electronics, pp. 74-77, San Jose, CA, Oct. 9-10, 1995.
E.R. Fossum, CMOS Image Sensors: Electronic Camera on a Chip (Plenary paper), in Technical Digest of the 1995 IEEE International Electron Devices Meeting (IEDM), pp. 17-25, Dec. 1995.
R.H. Nixon, S.E. Kemeny, C.O. Staller, and E.R. Fossum, 256x256 CMOS active pixel sensor camera on a chip, pp 178-179, Proc. IEEE International Solid-State Circuits Conference, San Francisco, CA February 1996.
R. Panicacci, S. Kemeny, P.D. Jones, C. Staller, and E.R. Fossum, 128 Mbit/second multiport CMOS binary active pixel image sensor, pp. 100-101, Proc. IEEE International Solid-State Circuits Conference, San Francisco, CA February 1996.
E.R. Fossum, Image capture circuits in CMOS, (invited) in Proc. 1997 International Symposium on VLSI Technology, Systems and Applications, pp.52-57, Taipei, Taiwan, June 3-5, 1997.
Z. Zhou, B. Pain, and E. Fossum, CMOS APS with on-chip buffer memory for variable resolution and light adaptive imaging, in Program of 1997 IEEE Workshop on Charge-Coupled Devices and Advanced Image Sensors, Bruges, Belgium, June 5-7 1997.
O. Yadid-Pecht and E.R. Fossum, CMOS APS image sensor with ultra-high linear dynamic range utilizing dual output, in Program of 1997 IEEE Workshop on Charge-Coupled Devices and Advanced Image Sensors, pp. R15.1-R15.3, Bruges, Belgium, June 5-7 1997.
J. Nakamura, T. Nomoto, T, Nakamura, B. Pain and E.R. Fossum, Design of a current mode image sensor with on-chip oversampling analog-to-digital conversion, in Program of 1997 IEEE Workshop on Charge-Coupled Devices and Advanced Image Sensors, pp. R23.1-R23.4, Bruges, Belgium, June 5-7 1997.
T. Shaw, B. Olson, B. Pain, R. Panicacci, B. Mansoorian, R. Nixon and E.R. Fossum, A single-chip CMOS APS digital camera, in Program of 1997 IEEE Workshop on Charge-Coupled Devices and Advanced Image Sensors, Bruges, Belgium, pp. R24.1-R24.4, June 5-7 1997.
B.Mansoorian, G. Yang, R. Panicacci, C. Staller, B. Pain, and E.R. Fossum, Megapixel CMOS APS with analog and digital readout, in Program of 1997 IEEE Workshop on Charge-Coupled Devices and Advanced Image Sensors, Bruges, Belgium, pp. R29.1-R29.4, June 5-7 1997.
E.R. Fossum, Non-linear output from image sensors: Applications, Techniques, and Limitations, in Program of 1997 IEEE Workshop on Charge-Coupled Devices and Advanced Image Sensors, Bruges, Belgium, p. D1, June 5-7 1997.
R.Panicacci, J. Alphonso-Gibbs, A.Cho, A. Krymski, N. Doudoumopoulos, R. Nixon, S.E. Kemeny and E.R. Fossum, 1/4-Inch CMOS Active Pixel Sensor With Smart On-Chip Functions And Full Digital Interface, in Proc. 1997 (9th) Hot Chips Symposium, Stanford University, Stanford, CA August 25-26, 1997.
E.R. Fossum, R. Nixon and D. Schick, A 37 mm x 28 mm 600k-pixel CMOS APS Dental X-ray Camera-on-a-Chip with Self-Triggered Readout, in Proc. IEEE International Solid-State Circuits Conference, pp. 172-173, San Francisco, CA February 1998.
Z. Zhou, B. Pain, and E.R. Fossum, A CMOS imager with on-chip variable resolution for light-adaptive imaging, in Proc. 1998 IEEE International Solid-State Circuits Conference, pp. 174-175, San Francisco, CA February 1998.
B. Mansoorian, H-Y. Yee, S. Huang, and E.R. Fossum, A 250 mW, 60 frames/s 1280x720 pixel 9b CMOS digital image sensor, in Proc. 1999 IEEE International Solid-State Circuits Conference, pp. 310-311, San Francisco CA February 1999.
S. Barna, L.P. Ang, B. Mansoorian, and E.R. Fossum, A low-light to sunlight, 60 frames/sec, 80kpixel CMOS APS camera-on-a-chip with 8b digital output, 1999 IEEE Workshop on CCDs and Advanced Image Sensors pp. 148-149, Nagano, Japan June 1999.
M.B. Kaplinsky, G. Waligorski, V. Berezin, and E.R. Fossum, Test methodologies for digital CMOS camera-on-a-chip image sensors, 1999 IEEE Workshop on CCDs and Advanced Image Sensors pp. 239-241, Nagano, Japan June 1999.
A. Krymski, D. Van Blerkom, A. Andersson, N. Bock, B. Mansoorian, and E.R. Fossum, A high speed, 500 frames/s, 1024x1024 CMOS active pixel sensor, 1999 Symposium on VLSI Circuits Digest of Technical Papers, pp. 137-138, Kyoto, Japan, June 1999.
K-B Cho, A. Krymski, and E.R. Fossum, A 1.2V micropower CMOS active pixel image sensor for portable applications, in Proc. 2000 IEEE International Solid-State Circuits Conference, pp. 114-115, San Francisco CA February 2000.
Y. Wang, S. Barna, S. Campbell, E.R. Fossum, A high dynamic range CMOS APS image sensor, Proc. 2001 IEEE Workshop on CCDs and Advanced Image Sensors, Lake Tahoe, NV, June 2001.
S. Ay, S. Barna, and E.R. Fossum, Differential mode CMOS active pixel sensor (APS) for optically programmable gate array (OPGA), Proc. 2001 IEEE Workshop on CCDs and Advanced Image Sensors, Lake Tahoe, NV, June 2001.
A. Krymski, N. Tu, D. VanBlerkom, E.R. Fossum, A high-speed, 240 frames per second, 4 megapixel CMOS sensor, Proc. 2001 IEEE Workshop on CCDs and Advanced Image Sensors, Lake Tahoe, NV, June 2001.
K.B. Cho, A. Krymski, and E.R. Fossum, A micropower self-clocked camera-on-a-chip, in Pgm. 2001 IEEE Workshop on CCDs and Advanced Image Sensors, Lake Tahoe, NV, June 2001.
Cho, K.-B.; Krymski, A.; Fossum, E.R, A 3-pin 1.5 V 550 uw 176 x 144 Self-clocked CMOS active pixel image sensor, Proceedings of the International Symposium on Low Power Electronics and Design, Digest of Technical Papers 2001. p 316-321 (IEEE cat n 01TH8581) , 2001
I.Takayanagi, J. Nakamura, E-S. Eid, E. Fossum, K. Nagashima, T. Kunihiro and H. Yurimoto, A low dark current stacked CMOS-APS for charged particle imaging, in Technical Digest of the 2001 IEEE International Electron Devices Meeting (IEDM), Washington, D.C., Dec 2001.
I.Takayanagi, M. Shirakawa, K. Mitani, M. Sugawara, S. Iversen, J. Moholt, J. Nakamura, and E. R. Fossum, A 1×1/4-inch 8.3Mpixel digital output CMOS APS for UDTV application, Proc. of 2003 IEEE International Solid-State Circuits Conference, San Francisco, CA, February 2003.
S. Iversen, J. Moholt, J. Solhusvik, I. Takayangi, J. Nakamura, E. R. Fossum, M. Shirakawa, K. Mitani, and M. Sugawara, An 8.3Mpixel, 10-bit, 60 fps CMOS APS, Proc. of 2003 IEEE Workshop on Charge-Coupled Devices and Advanced Image Sensors, Schloss Elmau, Bavaria, Germany May 2003.
M. Shirikawa, T. Yamashita, K. Mitni, M. Sugawara, I. Takayanagi, J. Nakamura, S. Iversen, J. Moholt, and E.R. Fossum, Design consideration of FPN suppression circuit for a 1.25” 8.3Mpixel digital output CMOS APS, Proc. of 2003 IEEE Workshop on Charge-Coupled Devices and Advanced Image Sensors, Schloss Elmau, Bavaria, Germany May 2003.
E. R. Fossum, Charge transfer noise and lag in CMOS active pixel sensors, Proc. of 2003 IEEE Workshop on Charge-Coupled Devices and Advanced Image Sensors, Schloss Elmau, Bavaria, Germany May 2003. Longer unpublished version
E.R. Fossum, Some Thoughts on Future Digital Still Cameras, pp. 305-314 in Digital Still Cameras, J. Nakamura editor, CRC Titles Press, 2005. ISBN: 0849335450
E.R. Fossum, What to do with Sub-Diffraction-Limit (SDL) Pixels? – A Proposal for a Gigapixel Digital Film Sensor (DFS), Proc. Of the 2005 IEEE Workshop on Charge-Coupled Devices and Advanced Image Sensors, Karuizawa, Japan, June 2005.
S. Ay and E.R. Fossum, A 76 x 77 mm2 16.85 million pixel CMOS APS image sensor, in 2006 IEEE Symposium on VLSI Circuits Digest of Technical Papers, June 2006.
R. Gutierrez, E.R. Fossum, T.Tang, Auto-Focus Technology, in Proceedings of the 2007 International Image Sensor Workshop, Ogunquit, Maine June 7-10, 2007.
E.R. Fossum, The 25th Anniversary of IISW: Reflections on Directions, in Proceedings of the 2011 International Image Sensor Workshop, Onuma, Hokkaido, Japan June 8-11, 2011.
T.Y. Lee, Y.J. Lee, D.K. Min, J. Lee, Y.G. Jin, Y.D. Park, and C. Chung, I. Ovsiannikov and E.R. Fossum, Dark Current Suppression during High Speed Photogate Modulation for 3D ToF Imaging Pixel, in Proceedings of the 2011 International Image Sensor Workshop, Onuma, Hokkaido, Japan June 8-11, 2011.
E.R. Fossum, Investigation of Two-Layer Photodetectors for YSNR10 Improvement in Submicron Pixels, in Proceedings of the 2011 International Image Sensor Workshop, Onuma, Hokkaido, Japan June 8-11, 2011.
T-Y. Lee, Y-J. Lee, D-K. Min, S-H. Lee, W.H. Kim, S.H. Kim, J.K. Jung, I. Ovsiannikov, Y-G. Jin, Y.D. Park, E.R. Fossum and C-H. Chung, A 192x108 ToF-3D Image Sensor with Single-Tap Concentric-Gate Demodulation Pixels in 0.13 um Technology, in Technical Digest of the 2011 IEEE International Electron Devices Meeting (IEDM), Wash. D.C. USA December 5-8, 2011.
W-J. Kim, Y. Wang, I. Ovsiannikov, S-H. Lee, Y.D. Park, C-H. Chung, and E.R. Fossum, A 1.5Mpixel RBGZ Image Sensor for Simultaneous Color and Range Image Capture, in Proceedings of the 2012 Int. Solid-State Circuits Conference pp. 391-392, San Francisco, CA, USA, February 22, 2012.
J.J. Helble, C.E. Fraser, and E.R. Fossum, Dartmouth’s Ph.D. Innovation Program, in 2012 American Soc. for Engineering Education (ASEE) Northeast Section Conference, Lowell, MA USA, April 27, 2012.
E.R. Fossum, Interview, pp. 17-30 (Chap. 2) in Inventors at Work: The Minds and Motivation Behind Modern Inventions, B. Stern, Apress, Oct. 17, 2012, ISBN: 1430245069
E.R. Fossum, Application of Photon Statistics to the Quanta Image Sensor, in Proceedings of the 2013 International Image Sensor Workshop, Snowbird, Utah USA June 12-16, 2013.
S. Chen, A. Ceballos, and E.R. Fossum, Digital Integration Sensor, in Proceedings of the 2013 International Image Sensor Workshop, Snowbird, Utah USA June 12-16, 2013.
S. Masoodian, Y. Song, D. Hondongwa, JJ Ma, K. Odame and E.R. Fossum, Early Research Progress on Quanta Image Sensors, in Proceedings of the 2013 International Image Sensor Workshop, Snowbird, Utah USA June 12-16, 2013.
Y. M. Wang, I. Ovsiannikov, S-J Byun, T-Y Lee, Y. Lee, G. Waligorski, H. Wang, S. Lee, D-K Min, Y.D. Park, T-C Kim, C-Y Choi, G.S. Han, and E.R. Fossum, Compact Ambient Light Cancellation Design and Optimization for 3D Time-of-Flight Image Sensors, in Proceedings of the 2013 International Image Sensor Workshop, Snowbird, Utah USA June 12-16, 2013.
J. Ma, D. Hondongwa, and E.R. Fossum, Jot Devices and the Quanta Image Sensor, (invited) in Technical Digest of the 2014 IEEE International Electron Devices Meeting (IEDM), pp. 247-250, San Francisco, CA December 15-17, 2014.
L. Anzagira and E.R. Fossum, Color Filter Array Patterns Designed to Mitigate Crosstalk Effects in Small Pixel Image Sensors, in Proceedings of the 2015 International Image Sensor Workshop, Vaals, The Netherlands, June 8-12, 2015.
L. Anzagira and E.R. Fossum, Two Layer Image Sensor Pixel Concept for Enhanced Low Light Color Imaging, in Proceedings of the 2015 International Image Sensor Workshop, Vaals, The Netherlands, June 8-12, 2015.
S. Masoodian, A. Rao, J. Ma, K. Odame and E.R. Fossum, A 2.5pJ Readout Circuit for 1000fps Single-Bit Quanta Image Sensors, in Proceedings of the 2015 International Image Sensor Workshop, Vaals, The Netherlands, June 8-12, 2015.
E.R. Fossum, Multi-Bit Quanta Image Sensors, in Proceedings of the 2015 International Image Sensor Workshop, Vaals, The Netherlands, June 8-12, 2015.
J. Ma, S. Masoodian, T-J. Wang and E.R. Fossum, Experimental Comparison of MOSFET and JFET 1.1μm Pitch Jots in 1Mjot Stacked BSI Quanta Image Sensors, in Proceedings of the 2017 International Image Sensor Workshop, Hiroshima Japan, May 30-June 2, 2017, pp. 226-229.
S. Masoodian, J. Ma, D. Starkey, Y. Yamashita, and E.R. Fossum, A 1Mjot 1040fps 0.22e-rms Stacked BSI Quanta Image Sensor with Cluster-Parallel Readout, in Proceedings of the 2017 International Image Sensor Workshop, Hiroshima Japan, May 30-June 2, 2017, pp. 230-233.
Eric Fossum publications.part01.rar
(14 MB , 下载次数:
70 )
Eric Fossum publications.part02.rar
(14 MB , 下载次数:
65 )
Eric Fossum publications.part03.rar
(14 MB , 下载次数:
66 )
Eric Fossum publications.part04.rar
(14 MB , 下载次数:
63 )
Eric Fossum publications.part05.rar
(14 MB , 下载次数:
102 )
Eric Fossum publications.part06.rar
(14 MB , 下载次数:
89 )
Eric Fossum publications.part07.rar
(14 MB , 下载次数:
68 )
Eric Fossum publications.part08.rar
(14 MB , 下载次数:
71 )
Eric Fossum publications.part09.rar
(14 MB , 下载次数:
93 )
Eric Fossum publications.part10.rar
(9.1 MB , 下载次数:
29 )
