查看: 2286|回复: 0
[求助] 数字后端LVS
发表于 2018-5-1 21:07:59 | 显示全部楼层 |阅读模式
大神们,小弟在做数字后端LVS检查时,报错如下:error:different numbers of nets
error:different numbers of instances
error: connectivity errors
initial numbers of objects
                 layout        source         component type
ports:            8              8
nets:             43            27
instances        25          23               MN(4pins)
                       25           23               MP(4pins)
                       2              0                 D( 2pins)
total inst:         52             46
numbers of objects after transformation
ports             8                    8
nets              33                  18
instances       21                 8           MN (4pins)
                      13                 4          MP (4pins)
                       0                  2          SPUP_2_1_1 (5 PINS)
                       2                  0           SMN2 (4PINS)
                       1                  0           SMP4 (6pins)
                       2                  0           SPMP_2_1_1 (6pins)
                       0                  4           _invb (6pins)
                       0                  3           _invv (4pins)
                       0                  1           _nor4v(7pins)
                       0                   2          _smn2v(4pins)
TOTAL INST     39                24
statistics:
  8  passthrough  layout  nets were found
  2  layout instances were filtered and their pins removed from adjoining nets
  1  layout net had all its pins removed and was deleted
求大神指导我该怎么做?
GMT+8, 2025-12-24 06:14 , Processed in 0.011486 second(s), 4 queries , Gzip On, Redis On.
