查看: 7906|回复: 10
[求助] spectra仿真报错
发表于 2018-3-30 11:51:00 | 显示全部楼层 |阅读模式
为什么是already defined呢。。。
这个报错什么意思啊。。
instance是使用的analoglib,然后仿真的时候添加了smic的lib
Error found by spectre during circuit read-in.
    ERROR (SFE-396): "/opt/cadence/SMIC_018_MMRF/SMIC_018_MMRF/models/spectre/ms018_v1p7_spe.mdl" 58: Model `n18' has already been defined.
    ERROR (SFE-396): "/opt/cadence/SMIC_018_MMRF/SMIC_018_MMRF/models/spectre/ms018_v1p7_spe.mdl" 143: Model `p18' has already been defined.
    ERROR (SFE-396): "/opt/cadence/SMIC_018_MMRF/SMIC_018_MMRF/models/spectre/ms018_v1p7_spe.mdl" 229: Model `n33' has already been defined.
    ERROR (SFE-396): "/opt/cadence/SMIC_018_MMRF/SMIC_018_MMRF/models/spectre/ms018_v1p7_spe.mdl" 318: Model `p33' has already been defined.
    ERROR (SFE-396): "/opt/cadence/SMIC_018_MMRF/SMIC_018_MMRF/models/spectre/ms018_v1p7_spe.mdl" 407: Model `nnt18' has already been defined.
    ERROR (SFE-396): "/opt/cadence/SMIC_018_MMRF/SMIC_018_MMRF/models/spectre/ms018_v1p7_spe.mdl" 490: Model `nnt33' has already been defined.
    ERROR (SFE-396): "/opt/cadence/SMIC_018_MMRF/SMIC_018_MMRF/models/spectre/ms018_v1p7_spe.mdl" 572: Model `nmvt18' has already been defined.
    ERROR (SFE-396): "/opt/cadence/SMIC_018_MMRF/SMIC_018_MMRF/models/spectre/ms018_v1p7_spe.mdl" 652: Model `pmvt18' has already been defined.
    ERROR (SFE-396): "/opt/cadence/SMIC_018_MMRF/SMIC_018_MMRF/models/spectre/ms018_v1p7_spe.mdl" 732: Model `nmvt33' has already been defined.
    ERROR (SFE-396): "/opt/cadence/SMIC_018_MMRF/SMIC_018_MMRF/models/spectre/ms018_v1p7_spe.mdl" 812: Model `ndio18' has already been defined.
    ERROR (SFE-396): "/opt/cadence/SMIC_018_MMRF/SMIC_018_MMRF/models/spectre/ms018_v1p7_spe.mdl" 828: Model `pdio18' has already been defined.
    ERROR (SFE-396): "/opt/cadence/SMIC_018_MMRF/SMIC_018_MMRF/models/spectre/ms018_v1p7_spe.mdl" 844: Model `ndio33' has already been defined.
    ERROR (SFE-396): "/opt/cadence/SMIC_018_MMRF/SMIC_018_MMRF/models/spectre/ms018_v1p7_spe.mdl" 860: Model `pdio33' has already been defined.
    ERROR (SFE-396): "/opt/cadence/SMIC_018_MMRF/SMIC_018_MMRF/models/spectre/ms018_v1p7_spe.mdl" 876: Model `nwdio' has already been defined.
    ERROR (SFE-396): "/opt/cadence/SMIC_018_MMRF/SMIC_018_MMRF/models/spectre/ms018_v1p7_spe.mdl" 892: Model `nndio18' has already been defined.
    ERROR (SFE-396): "/opt/cadence/SMIC_018_MMRF/SMIC_018_MMRF/models/spectre/ms018_v1p7_spe.mdl" 908: Model `nndio33' has already been defined.
    ERROR (SFE-396): "/opt/cadence/SMIC_018_MMRF/SMIC_018_MMRF/models/spectre/ms018_v1p7_spe.mdl" 924: Model `diobpw' has already been defined.
    ERROR (SFE-23): "input.scs" 17: The instance `M0' is referencing an undefined model or subcircuit, `nmos4'. Either include the file containing the definition of `nmos4', or define `nmos4' before running the simulation.
发表于 2018-3-31 10:24:27 | 显示全部楼层
这个问题我也遇到过,最后不用analoglib里的模型,直接用工艺库提供的n18的symbol画的电路
 楼主| 发表于 2018-3-31 12:29:52 | 显示全部楼层
回复 2# s橙子s
    这个我解决了。。。最后只留下tt那个lib,别的全部都不选。。。
发表于 2018-3-31 18:48:03 | 显示全部楼层
回复 3# franzjoseph
   哦哦,看来我也试试
发表于 2018-3-31 22:14:10 | 显示全部楼层
 楼主| 发表于 2018-4-2 15:25:53 | 显示全部楼层
回复 5# 122013137
    这个搞定了,管子的名字要加上所调用的库的管子的命名
发表于 2018-4-2 17:15:58 | 显示全部楼层
重复调用相同模型了。
 楼主| 发表于 2018-4-2 20:46:37 | 显示全部楼层
回复 7# thincat
    只调用lib文件就行了,之前我把mdl文件也选上了
发表于 2020-3-4 17:09:30 | 显示全部楼层
我也解决了,就是model name没改过来 添加的器件P33 modelname 是poms,在schematic左边窗口选中mos管,修改过来就好了
发表于 2020-10-19 20:06:39 | 显示全部楼层
感谢楼主,按照这个帖子终于把问题解决了
GMT+8, 2025-10-23 11:25 , Processed in 0.021885 second(s), 3 queries , Gzip On, Redis On.
