查看: 1164|回复: 0
[招聘] [AMD实习] Validation Intern
发表于 2018-3-21 11:24:21 | 显示全部楼层 |阅读模式
AMD超威半导体上海研发中心招聘 Validation Intern, 请应聘者将简历发送到 Cherry.Zhang@amd.com
Graphics Validation Intern
What you do at AMD changes everything
At AMD, we push the boundaries of what is possible.  We believe inchanging the world for the better by driving innovation in high-performancecomputing, graphics, and visualization technologies – building blocks forgaming, immersive platforms, and the data center.
Developing great technology takes more than talent: it takes amazing people whounderstand collaboration, respect, and who will go the “extra mile” to achieveunthinkable results.  It takes people who have the passion and desire todisrupt the status quo, push boundaries, deliver innovation, and change theworld.   If you have this type of passion, we invite you to take alook at the opportunities available to come join our team.
JOB DESCRIPTION
  • Execute tests (functional stress) on AMD APU/GPU     projects with internal and external applications & tools under     different OSes.
  • Track test status correctly and finish test report in     time.
  • Write correct issue report independently.
  • Work with validation engineer / debug engineer to find     failure root cause.
  • Attend meetings periodically and provide weekly report     to leaders.
  • Other duties as assigned by team leader
  • Demonstrates discipline in execution of tasks and     flexibility/adaptability to frequent changes.
REQUIREMENT
Canwork at least 4 days a week and last for at least 6 months
  • Knowledge of PC products (CPU, graphic card,     motherboard) and peripherals (DIMM, Hard Disk, Monitor, SD, SATA, USB….)
  • Understand discrete Graphic Card and x86 architecture.
  • Familiar with Windows OSes. Experience in system     management will be a plus. Experience of Linux is a plus.
  • Perl, C/C++, Ruby, assembly language, object oriented     programming skills and command line scripting preferred.
  • Willing to perform shift hours when required.
  • Good team worker and willing to work overtime and work     under pressure.
  • Good solder skill and hardware test background(e.g.     experience on operating scope) is a plus
  • CET-4. CET-6 will be a plus.
GMT+8, 2025-10-15 01:04 , Processed in 0.011647 second(s), 4 queries , Gzip On, Redis On.
