查看: 4780|回复: 4
[求助]cadence IC617 打不开
发表于 2018-2-19 01:19:46 | 显示全部楼层 |阅读模式
系统提示virtuoso:   ERROR: The command /home/oskar/cadence/installs/IC615/oa_v22.41.022/bin/sysname returned an error status:
                            unknown
virtuoso:    INFO: Note that OpenAccess (OA) requires running the Configure phase.
virtuoso:          See the "OpenAccess Installation and Configuration Guide" before
virtuoso:          you complete the configuration step. This manual is included with
virtuoso:          the Cadence product documentation.
patch也打了 license也弄了
系统是ubuntu 16.04LTS
求大佬帮帮忙 谢谢您!
新年快乐!
 楼主| 发表于 2018-2-19 10:19:45 | 显示全部楼层
自定哈
发表于 2018-2-23 18:04:50 | 显示全部楼层
you should run configuration after the installation.
Or create the right path or link to your OA
发表于 2018-2-23 19:37:24 | 显示全部楼层
回复 1# jn9702
   setenv OA_HOME  /home/oskar/cadence/installs/IC615/oa_v22.41.022
  export OA_HOME=/home/oskar/cadence/installs/IC615/oa_v22.41.022
发表于 2021-1-16 21:24:28 | 显示全部楼层
designstart 发表于 2018-2-23 19:37
回复 1# jn9702
感謝分享!
GMT+8, 2025-12-29 03:40 , Processed in 0.014759 second(s), 3 queries , Gzip On, Redis On.
