查看: 4234|回复: 4
[讨论] VCS syntax error
发表于 2018-2-1 05:22:03 | 显示全部楼层 |阅读模式
in my design folder I have these verilog files:bandrate_generate.v
ceshi_uart_test.v
ceshi_uart.v
uart_rx.v
uart_tx.v
I used this command line to compile the test case:
vcs ceshi_uart.v bandrate_generate.v uart_rx.v uart_tx.v ceshi_uart_test.v -y . +libext.+v
and got error message:
Error-[SE] Syntax error
  Following verilog source has syntax error :
  "bandrate_generate.v", 5: token is 'module'
  module bandrate_generate ( input clk, input rst_n, input [1:0] state, output
  band_tick);
bandrate_generate
* file name: bandrate_generate.v
* module bandrate_generate #(parameter bandrate = 9600) (
module bandrate_generate ( input clk, input rst_n, input [1:0] state, output band_tick);
//此处initial语句是可以综合的,因为是预先计算的。
/************* initial the bandrate *******************/
2 warnings
1 error
CPU time: 1.168 seconds to compile
and the bandrate_generate.v read like this:
line 5:
I don't understand what did it complain. I failed to see anything wrong with the line 5
Please help
发表于 2018-2-2 14:17:35 | 显示全部楼层
bandrate_generate的完整代码能否贴一下?可以发图片。
发表于 2018-2-2 22:53:24 | 显示全部楼层
回复 1# xiaoyisimonguo
   有没有加endmodule?
发表于 2018-2-4 20:13:58 | 显示全部楼层
endmodule加了吗?另外vcs是否添加了支持verilog2005命令?
发表于 2023-1-9 15:53:34 | 显示全部楼层
遇到了这个问题,有个看法是,不一定实在module的地方有语法错误。可能是编译这文件之前的错误。
GMT+8, 2025-12-27 17:15 , Processed in 0.014170 second(s), 3 queries , Gzip On, Redis On.
