查看: 3116|回复: 3
[转贴] Bias Circuit Design For 1nA using UMC 180nm PDK
发表于 2018-1-31 21:47:35 | 显示全部楼层 |阅读模式
Hi,           I have to Design 1nA bias circuit with  Nmos and Pmos cascade transistors but in UMC 180nm pdk  maximum length allowable is 50um.. how to design such low bias circuit please need your help..
Thanks in advance...
发表于 2018-2-2 10:36:14 | 显示全部楼层
1nA, 异想天开~~~关断漏电通常都是0.1uA~1uA
 楼主| 发表于 2018-2-5 18:20:00 | 显示全部楼层
"An 1-V, 74-dB, sub-Hz Gm-C filter based on a modular transconductance reduction technique"
In This work authors designed OTA with tail current range from 0.1nA to 10nA...
How to design 1nA cascade bias circuit using UMC 180nm PDK...
thanks in advance..
发表于 2018-2-22 08:28:46 | 显示全部楼层
thanks for your sharing
GMT+8, 2025-12-24 17:39 , Processed in 0.018182 second(s), 4 queries , Gzip On, Redis On.
