发表于 2018-6-28 15:06:38
显示全部楼层
回复 6# okfunny
Sorry, no Chinese input at the this computer.
I cannot agree more. If you know SKILL more, then you see the schematic and layout (design database) in a totally different way (imagining Neo seeing the agents as the green digital flow in "The Matrix" )
You can do a lot of automation in schematic, ADEXL, layout etc. Which can dramatically save you a lot of time.
And you can even create your own calculator expressions for post process.
If you just want to use by your self, then you do not need to know much about the "form(GUI)". Otherwise your work will be doubled for wrapping your code with GUI for others.
Anyway, the effort spent on SKILL will definitely being paid back. As far as you getting families with coding, then linux script, verilog/a/ms, UVM is not a big barrier for you. All of these will help you for work efficiency and broaden your career path.
Good luck and Have fun |
