查看: 8872|回复: 2
[求助] virtuoso转出CDL(spice Netlist)出现问题
发表于 2017-12-3 11:03:34 | 显示全部楼层 |阅读模式
我想自己画一个电路图,然后在virtuoso里面依据我画出的电路图,来画IC Layout
我已经服务器里面放置了想关tf drf drc的档案,就欠一章电路图~~
所以我使用cadence里面的composer-schematic 这个功能来画电路~
我使用symbolvirtuoso里面的analogLib叫出来的~~
后来我画完有check and save , 接着要Export CDL
但出现failed.....后来我查询了一下
出现底下错误:
Running Artist Hierarchical Netlisting ...
ERROR: Netlister: unable to descend into any of the views defined in theview
list: "auCdl schematic" for instance I10 in celllayout_example.
Either add one of these views to: Library: analogLib Cell: dummy ormodify
the view list to contain an existing view.
End netlisting Dec  3 10:48:552017
ERROR (OSSHNL): Error(s) found during netlisting. The netlist may becorrupt
or may not be produced at all.
To generate correct netlist, fix the errors and re-netlist.
~~可是我的电路图没使用I10的组件啊~~~
eetop的版友...谁可以帮帮我啊~~
   谢谢 ~~~~~
发表于 2017-12-5 00:54:37 | 显示全部楼层
I10 是啥cell呀?可不可以skip掉?
发表于 2019-11-5 15:59:58 | 显示全部楼层
I10是自动生成网络标号,无法生成cdl,有可能是自带库的ipin、 opin、 in 、out有问题,删除就可以生成cdl
GMT+8, 2025-11-6 03:21 , Processed in 0.365182 second(s), 3 queries , Gzip On, Redis On.
