查看: 2229|回复: 1
blockage for scan chain cells
发表于 2017-12-3 02:15:48 | 显示全部楼层 |阅读模式
is it possible to create a Blockage which is specific to Scan-Chain related FF. Means no FF in that region should part of Scan chain logic.
发表于 2017-12-4 13:13:35 | 显示全部楼层
回复 1# pradeepmadhava1
Can we just put those design in a module or file and synthesis those design by using general FF cells?
When we run the whole chip synthesis, just use "don't touch" command to block any change to these designs.
GMT+8, 2025-12-26 01:10 , Processed in 0.014258 second(s), 4 queries , Gzip On, Redis On.
