查看: 2341|回复: 1
[讨论] ICC run to finish, but not I/O connection for VDD/VSS
发表于 2017-11-3 14:18:33 | 显示全部楼层 |阅读模式
Ran through ICC from setup to routed and dfm filled
But somehow the power/ground connections on I/O pads is not there, please see the picture.
we could see the port on VSS_3 ground pad. The VSS bus is just right above. The VSS port/terminal is METAL2 through METAL4.
A simple METAL2 path with Via12 array on VSS bus would be sufficient. I thought the operation should be done in preroute stage.
My preroute  command in tcl is below:
preroute_instances -route_pins_on_layer METAL4 -nets {VDD VSS}  -primary_routing_layer pin -extend_for_multiple_connections -extension_gap 10.0
I don't know what did I miss here, and I am struggling with this for a long time. Please help
 楼主| 发表于 2017-11-28 05:49:55 | 显示全部楼层
回复 1# xiaoyisimonguo
   please help, all the experts
GMT+8, 2025-11-25 03:10 , Processed in 0.014562 second(s), 5 queries , Gzip On, Redis On.
