楼主: chip2222
【Keysight_ADS2017_Win64_CRACK】
发表于 2018-3-24 10:05:42 | 显示全部楼层
zhemneqiangda a
发表于 2018-3-24 10:19:01 | 显示全部楼层
破解完全嘛?
发表于 2018-3-24 11:42:26 | 显示全部楼层
take a look...
发表于 2018-3-24 11:46:20 | 显示全部楼层
大佬有ADS2017 linux版的破解文件吗?
发表于 2018-3-24 14:23:31 | 显示全部楼层
看看,谢谢楼主!!!
发表于 2018-3-24 14:33:03 | 显示全部楼层
路过学习一下
发表于 2018-3-25 01:36:54 | 显示全部楼层
请问用了crack之后,可以进行FEM仿真吗?
发表于 2018-3-25 08:41:54 | 显示全部楼层
学习了,谢谢版主
发表于 2018-3-25 11:06:31 | 显示全部楼层
GooooooooooooooooooD!
发表于 2018-3-25 11:32:24 | 显示全部楼层
回复 1# chip2222
求助,FEM仿真出现如下错误,系统是win10。 Momentum仿真没有问题。谢谢!
  Momentum MomEngine_64 12.60.405 (*) built: Oct  6 2017
Copyright  1999 - 2017 Keysight Technologies
Automatically determined a snap distance of
0.0022 mil for layout healing.
Setting EMPROHOME to D:\Program Files\Keysight\ADS2017\fem\2017/Win32_64/bin
FemEngine
Version:FEM FemEngine_64 12.60 (*) built: Oct  6 2017
Target dataset file: LOWPASSFILTER_FEM
empro-build-2017-08-10-charizard 330.rday r486903 (64-bit)
Except 0
Traceback (most recent call last):
  File "D:\Program Files\Keysight\ADS2017\Momentum\12.60\fem_scripts\sim.py", line 1077, in import_settings_and_simulate
    self.openOrCreateEMProProject(proj, stop_after_project_creation)
  File "D:\Program Files\Keysight\ADS2017\Momentum\12.60\fem_scripts\sim.py", line 738, in openOrCreateEMProProject
    self.cleanFrequencyPlan()
  File "D:\Program Files\Keysight\ADS2017\Momentum\12.60\fem_scripts\sim.py", line 838, in cleanFrequencyPlan
    frequency_plan_list=empro.activeProject.createSimulationData().femFrequencyPlanList()
Exception: Cannot make request activeProject(), License not found
(agilent::activeProject)
Could not check out license for Reading a project: Reading a project
The desired vendor daemon is down
Possible Causes:
1. lmgrd process is running, but not the agileesofd vendor daemon. The software was able to contact the license server (lmgrd), but the vendor daemon (agileesofd) did not respond.
2. agileesofd vendor daemon has crashed or has been terminated.
3. lmgrd process was shut down manually or via LMTools with -x lmdown option
4. On Windows platform, this could be caused by waking up from Sleep or Hibernation mode.
5. The logfile was unable to be removed.
Troubleshooting Tips:
1. Check the license server's debug log file and try lmreread.
2. Reboot your system to restart the license service.
3. Use LMTools to clear your previous setup first, then restart license setup wizard to re-configure your license.
4. Shut down the lmgrd process and check that lmgrd or agileesofd processes are no longer running. Restart the license server.
5. Stop lmgrd via kill pid (UNIX) withough -9 argument or stop the lmgrd process through the Windows Task Manager or Windows Service.
6. Close all processes that are reading the logfile.
License Requested:  empro_sipi_3D_read
License path:  D:\Program Files\Keysight\ADS2017\license.lic
GMT+8, 2025-12-14 14:08 , Processed in 0.019856 second(s), 3 queries , Gzip On, Redis On.
