查看: 3426|回复: 0
Communications Systems Test Engineer
发表于 2007-6-29 10:54:45 | 显示全部楼层 |阅读模式
Atheros Communications is a leading developer of semiconductor system solutions for wireless communications products.  Atheros combines its wireless systems expertise with high-performance radio frequency (RF), mixed signal anddigital semiconductor design skills to provide highly integrated chipsets that are manufacturable on low-cost, standard complementary metal-oxide semiconductor (CMOS) processes.  Atheros technology is being used by a broad base of leading customers, including personal computer, networking equipment
and consumer device manufacturers.  For more information, visit www.atheros.com.
Requirements
As communications system test engineer you will be responsible developing test infrastructure, implementation and execution of test cases, as well as running interoperability tests, for our Bluetooth PC solution. You will work with the software and digital team, influence the design, and make sure the implementation is compliant with the Bluetooth specifications.
Qualifications
- BS in Computer Science, Electrical Engineering or equivalent with 2 years or more of experience.
- Experience with testing wireless communication systems is a must.
- Good knowledge of how to diagnose, debug, and describe system test failures.
- Experience with embedded systems containing a SoC.
- Experience with Bluetooth protocols and profiles is a plus.
- Team player with good communication skills.
如果有意,请将简历发送到syuan@atheros.com.
GMT+8, 2025-12-25 20:59 , Processed in 0.016502 second(s), 6 queries , Gzip On, Redis On.
