查看: 3277|回复: 0
[求助] SDSOC 编译错误
发表于 2017-10-30 16:27:33 | 显示全部楼层 |阅读模式
hi:
我用SDSOC2017.1建立一个空白工程,添加了简单的。c和。h文件,然后编译显示
Using prebuilt hardware
Skipping block diagram (BD), address map, port information and device registration for partition 0
Software tracing enabled
Prepare hardware access API functions
Create accelerator stub functions
Compile hardware access API functions
Compile accelerator stub functions
Create board support package library
Preliminary link application ELF
ERROR: [SdsCompiler 83-5042] ERROR: number of files portinfo.h (0) does not match number of partitions (1)
sds++ log file saved as D:/project/aes/Debug/_sds/reports/sds.log
ERROR: [SdsCompiler 83-5004] Build failed
make: *** [aes.elf] 错误 1
这是什么原因?我没有添加portinfo。h文件,应该是自带的吧
另外xilinx的官网论坛怎么回事,发表新帖,总是要你证明自己不是机器人。发不了
GMT+8, 2025-12-29 03:03 , Processed in 0.014091 second(s), 4 queries , Gzip On, Redis On.
