查看: 1520|回复: 0
[招聘] 【AMD社招】Front-End Integration Engineer
发表于 2017-9-26 16:06:35 | 显示全部楼层 |阅读模式
AMD超威半导体上海研发中心招聘 SMTS Front-End Integration Engineer, 请将简历发送到 Cherry.Zhang@amd.com
RESPONSIBILITIES:
The successful candidate will assume technical leadership of a complex design generally including custom digital logic, an embedded u-controller and analog functionality. The following is a list of key responsibilities that the candidate will assume:
-        Micro-architecture of digital blocks, hardware firmware partitioning.
-        Leading a small team of engineers
-        Digital design and RTL coding for.
- Writing firmware for embedded u-controllers in C
-        Occasional creation of utility software in using C++, perl, php
-Co-ordinating design verification and implementation activities.
REQUIREMENTS:
-        Minimum 5-6 years of experience with Verilog a MUST
-        Excellent knowledge of verilog, C, C++ and a scripting language; experience with Perl and TCL is a plus
-        Strong understanding of digital and analog electronics.
- Experience with low level, physical phenomena oriented logic design is an asset (dealing with IO, clocking, voltage control, etc.)
-        Power/thermal management experience is an asset.
-        Security/cryptography experience is an asset
-        Good understanding of computer organization/architecture.
-        Laboratory experience, including the use of equipment: oscilloscopes, logic analyzers, etc.
-        Strong analytical/problem solving skills and pronounced attention to details.
-        Must be a self starter, and able to independently drive tasks to completion.
-        Strong interpersonal and communication skills
EDUCATION:
-        Bachelor, Master's or PhD degree in Electrical or Computer engineering.
GMT+8, 2025-11-4 05:30 , Processed in 0.010690 second(s), 3 queries , Gzip On, Redis On.
