查看: 2117|回复: 0
[原创] 【稳定方案】NCS8805:LVDS/RGB转EEDP芯片支持4K
发表于 2017-9-18 18:27:12 | 显示全部楼层 |阅读模式
The NCS8805 is a display format converter with Hi-Fidelity scaling function. Sitting between the application processor and the LCD panel, it bridges the gaps between different display interfaces and different resolutions. The goal is to let our customer completely get over the issue of display compatibility.
Features
  • Ÿ Covers a wide range of display format
Multiple input/output interfaces supported
Output resolution from HD to 4K
Input resolution from HD to 2K
  • Ÿ Advanced fractional scaler
       Hi-Fidelity scaling
Supports any scaling ratio between 1:2 and 2:1
  • Ÿ Low power consumption
GMT+8, 2025-12-23 01:37 , Processed in 0.015314 second(s), 3 queries , Gzip On, Redis On.
