查看: 2664|回复: 2
[求助] 关于noise figure
发表于 2017-9-5 14:28:07 | 显示全部楼层 |阅读模式
使用noise分析得出来的noise figure和用sp分析得出来的NF有什么区别么,仿真出来感觉不太一样啊,用sp仿真出来的要小一些这是为什么,求助,thx
发表于 2020-5-31 13:18:15 | 显示全部楼层
同问,用PSS+PNOISE仿真的LNA的NF和SP仿真的LNA的NF差的很大
发表于 2020-6-1 13:26:30 | 显示全部楼层
If you use SP analysis, it gives you the small signal NF, namely, the DC biasing points are fixed. However, if you use PSS or HB, it is large signal analysis, DC biasing points are varying with input signals. The two corresponding results are obviously different then.
The differnet results between SP analysis and nosie analysis is due to your set-up, if your set-up is correct, you should obtain similar results
GMT+8, 2025-12-26 01:03 , Processed in 0.013119 second(s), 4 queries , Gzip On, Redis On.
