查看: 2035|回复: 3
weird problem in different machine, please help
发表于 2017-9-1 01:17:49 | 显示全部楼层 |阅读模式
I installed synopsys scl11.9 into one of our laptop, F26
one of the command in the package is lmhostid: on this machine:
/home/tools/synopsys/scl11.9/linux/bin/lmhostid
yielded:
lmhostid - Copyright (c) 1989-2014 Flexera Software LLC. All Rights Reserved.
The FlexNet host ID of this machine is ""2477031b04f0 d067e53aa071""
Only use ONE from the list of hostids.
Then I back up this package to another machine also F26
now
I got:
/home/tools/synopsys/scl11.9/linux/bin/lmhostid: Command not found.
I went to the bin directory:
ls -l lmhostid
-rwxr-xr-x. 1 dubeeloo dubeeloo 1031280 Nov 4 2014 lmhostid
I checked the OS, they are both the same:
Linux xiian 4.12.8-300.fc26.x86_64 #1 SMP Thu Aug 17 15:30:20 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
Linux codelion 4.12.8-300.fc26.x86_64 #1 SMP Thu Aug 17 15:30:20 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
I could not tell anything different, Please help
发表于 2017-9-1 01:30:50 | 显示全部楼层
The 64 bit system does not recognize the 32 bits binary:
You have two options:
1) use the 64 bits daemon
2) Install i386 package(yum install glibc.i686), and you could refer to the following post:
https://unix.stackexchange.com/q ... on-64-bit-fedora-17
发表于 2017-9-1 10:07:32 | 显示全部楼层
谢谢楼主分享
 楼主| 发表于 2017-9-1 12:09:39 | 显示全部楼层
回复 2# churchmice
    thank you for your reply
the weird part is one, xiian, could run without issue. while codelion just reportcommand mot found
GMT+8, 2025-10-28 12:19 , Processed in 0.020161 second(s), 3 queries , Gzip On, Redis On.
